Please check your PHP error logs and see if anything is being logged.
Audit log page 500 error
So I think this is a windows specific issue. Apparently windows is not smart enough to find the file when there is an extra slash in the path (yet another reason why I HATE windows).
We are going to push a commit soon to address this issue but in the meantime you can search for /plugins/audit.phar
in the codebase and change every reference of /plugins/audit.phar
to plugins/audit.phar
. TLDR just remove the extra slash at the beginning.
Hi I had the same issue. After the update everything worked fine. After installing the Audit Log plugin every page shows a 500 error. The only solution was a backup
If anyone else has this issue, please try removing the plugin and see if the site comes back.
If you can't use the UI to do this then please disable the plugin in the ost_plugin table.
Hi BrettR
Just came across this issue myself, wasn't able to access the dashboard audit logs, i found that changing 19th and 21st line in the audits.php (\htdocs\System-name\scp) helped
require_once(sprintf('phar:///%s/plugins/audit.phar/class.audit.php', INCLUDE_DIR));
$page= sprintf('phar:///%s/plugins/audit.phar/templates/auditlogs.tmpl.php', INCLUDE_DIR);
to:
require_once(sprintf('phar://%s/plugins/audit.phar/class.audit.php', INCLUDE_DIR));
$page= sprintf('phar://%s/plugins/audit.phar/templates/auditlogs.tmpl.php', INCLUDE_DIR);
Like KevinTheJedi mentioned there seemed to be an extra / in the path
hope this helps
Richard-Treanor
This worked! Thank you so much.
Had same error, this worked, thank you Richard-Treanor
I have the same issue, but in other everimonet
When a i go to "control panel" -- "Audit logs" i recibe a error 500.
CentOS Linux release 8.1.1911 (Core)
PHP 7.4.4
mysql Ver 15.1 Distrib 10.3.17-MariaDB
Apache/2.4.37 (centos)
Log apache:
"GET /scp/audits.php HTTP/1.1" 500 - "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36"
I look for the Richard-Treanor recomendation, i found a "///" and change. But the error persist.
¿something to check?
Thanks!!!
@Gastondc then you do not appear to have the "same issue".
This issue only appears in a windows server environment.
In your case it could be:
- You are running a version of PHP that osTicket does not support yet.
- SELinux (or some other security feature like mod_security) could be preventing the file from being opened.
Did disabling SELinux fix your issue?
Hi , can some help me with this error HTTP 5000 when i click on audit page , i have installed plugin audit
i am running with this configuration installed in RHEL7
osTicket Version v1.14.1 (f1e9e88) — v1.14.2 is available
Web Server Software Apache/2.4.6 () OpenSSL/1.0.2k-fips PHP/7.4.8
MySQL Version 5.5.65
PHP Version 7.4.8
