You cannot add a form.
You can add a variable/column.
Then you click Add New and in the Primary Data Source you select the variable you want to add.
ntozier where ? i can't find the Primary Data Source.. http://prntscr.com/novcch
Add new first.
Then select the data source.
Then you are not running the current Stable (1.12).
Official Doc site:
https://docs.osticket.com/en/latest/Getting%20Started/Upgrade%20and%20Migration.html
The article I wrote for going from 1.10 to 1.11 (although outdated the procedure does not change). note: if you are on 1.11 and going to 1.12 the upgrader will not run as there is no database structure changes.
https://tmib.net/upgrading-osticket-1-10-x-to-current-1-11-0/
i have the last version http://prntscr.com/nozp6j
Great, it sounds like you are all set. Should I close this thread?
You are at: Admin panel -> Settings -> Tickets: on the Queues tab?
Fixed!
You can close the thread! thank you for help me!
Very welcome.
Please feel free to start a new thread if you have another question, comment, etc.
