I have try to ping the cURL oauth2.googleapis.com/token, it return 'Ping request could not find host'
when i ping oauth2.googleapis.com. it able to ping successful.
What should i do ?
Thanks your advise
What should i do ?
Thanks your advise
I would suggest googling the error or contacting your server admin/network provider for further assistance. I have not seen this issue before.
i have try to connect my mobile data and do testing the message change
here is the message 'The scheme '' is not supported.'.
Do you have and idea in this ?
Thanks for your reply
I haven’t seen that error before. Are you sure you followed these steps exactly?
Are you using a US Gmail account (ie. @gmail.com
If it’s an @gmail.com
personal email (ie. non-google workspace account) and you made the Project External then you need to add the email you are trying to authorize to the Test Users within the Project.
I have follow the step exactly, my is personal gmail.
The project user type is external.
I have added the email into Test users
I just tried googling that error and can’t find anything about it. Unfortunately I wouldn’t be of much help if you’ve read the documentation, followed all the steps, met all the requirements, and have all prerequisites installed.
I have try to ping the https://oauth2.googleapis.com/token using mobile data it was success reach.
so i use the mobile data to do authentication. it return "Connection refused for URI https://oauth2.googleapis.com/token
for this message, do you have any advise ?
I do not, no. You'll have to google that error to see. To me it seems like firewall issue but there’s no way to be certain without you digging deeper.
Hi i have success login by normal email authentication.
I have try to Diagnostic to send email out. it was success.
When i send new email to create ticket, it was fail
i have check my mailbox it was success deliver but in osTicket didn't create ticekt.
Would like to ask your assist.
Thanks for you reply
Did you enable email fetching (Admin Panel > Emails > Settings > Email Fetching)? Did you create a cron job/scheduled task?
I have crated the api, and here is the code in cron.php
How to run in localhost ?
<?php
cron.php
File to handle LOCAL cron job calls.
Peter Rotich <peter@osticket.com>
Copyright (c) 2006-2013 osTicket
http://www.osticket.com
See LICENSE.TXT for details.
@chdir(dirname(FILE).'/'); //Change dir.
require('api.inc.php');
if (!osTicket::is_cli())
die(__('cron.php only supports local cron calls - use http -> api/tasks/cron'));
require_once(INCLUDE_DIR.'api.cron.php');
LocalCronApiController::call();
'url'=>'C:/inetpub/wwwroot/osTicket2/api/tasks/cron',
'key'=>'3D899DDAE50710DA6BA5A12503D6A8F1'
You don’t need to use api at all if you are running cron locally. Simply look at the "RECURRING TASKS SCHEDULER (CRON JOB)" section for an easy example.
Can the user change to agent?
I want to create an agent but the email already exist in user.
so want to change the user become agent.
How to configure? i registered the user.
You can have both a user account and agent account. To add a new agent go to Admin Panel > Agents > Agents and click Add New Agent.
Is that possible the SLA calculate date/time depend on the ticket status
For example,
I have create Pending status for the ticket.
if the ticket status is pending, SLA count down stop, when it change to "In Progress" then start / continue countdown
Regarding the new agent, unable use same email created in user and agent.
User table already created, when i create as an agent, it show "email already exist"
here is the screenshot
and this is the screenshot from user screen
An SLA can be Transient or non-Transient. If Transient it can be overridden on Help Topic change or Department Transfer. There is no way to change SLA on Ticket Status changes.
By default SLAs calculate DueDate times based on the Grace Period starting immediately once the Ticket is created or once the SLA is set. With that being said, SLAs can calculate DueDate times based on an attached Schedule. So if you want you can create a specific Schedule that’s always a holiday, create your SLA named "Pending", attach the holiday Schedule you created, and now once your Agents set the Status Pending they can also set the SLA to "Pending" so the SLA timer stops calculating. Then once they are ready they can set the SLA to whatever they want and it will calculate a new DueDate.
As for the Agent email issue, the error is saying you have a System Email (Admin Panel > Emails > Emails) with the same address. An Agent cannot have the same address as a System Email and vice versa.
Possible create a SLA don't have countdown. every ticket must has SLA Plan, so when i choose SLA Pending there is unlimited time so don't have overdue or don't have count down so don't have overdue.
Thanks & Regards
