lupo_gris
I guess you didn't read the post I linked above with full instructions. Your Resource Details Endpoint is incorrect. You should be using the v2.0 outlook api url https://outlook.office.com/api/v2.0/me. Please make sure you download and install the latest build of the OAuth2 plugin from our website.
Also, your scopes are wrong. You need to use the outlook scopes of offline_access https://outlook.office.com/Mail.ReadWrite.
    BrunoLopes Did you manage to solve it? I tried with incognito, but I still get that Email Mismatch.
    To get that error, I log into a shared mailbox after it asks me to sign with an admin account to authorize the access to the organisation.
    KevinTheJedi I made the changes, but still in "invalid client".. I download and reinstall the plugin with the same result
    edit:
    I made a fresh install, without de data of the old OST, and work... so something about the original OST is broken...
      lupo_gris
      Did you enable and consent to the needed scopes in your Azure App? Please go back to my linked guide and follow all the steps.
        lupo_gris
        These settings have worked for me
        email Address Attribute part, you have different, based on your AD settings
        Client Id: *
        IdP Client / Application Identifier
        Client Secret:
        IdP Client Secret
        Scopes: *
        Comma or Space separated scopes depending on IdP requirements
        offline_access https://outlook.office.com/IMAP.AccessAsUser.All https://outlook.office.com/POP.AccessAsUser.All https://outlook.office.com/SMTP.Send
        Authorization Endpoint: *
        Authorization URL
        https://login.microsoftonline.com/common/oauth2/v2.0/authorize
        Token Endpoint: *
        Access Token URL
        https://login.microsoftonline.com/common/oauth2/v2.0/token
        Resource Details Endpoint: *
        User Details URL
        Email Address Attribute: *
        Please consult your provider docs for the correct attribute to use
        emailAddress
        Callback Endpoint: *
        Redirect Uri
        https://YourSupportTicketAddress.com/api/auth/oauth2
        Our token expired and app won't fetch emails. So, app should have extra permissions in Azure App? Anyway, on SMTP configuration token is valid.
        Update: After go to setting token and click on confirm, token refresh and valid but still main won't fetch emails form Inbox.
          I tried with plugin version 0.3 and the redirect url does not work. it just redirects to the homepage when authenticating.
          Version 0.5 does not open configuration, just a blank popup.
          Any here with a working version?
            sander4000
            Check the network traffic with the developer tools (usually "F12"). Sometimes it shows you the error as soon as you got redirected.
            KevinTheJedi yes, all configuration are correct... in a fresh ost (without data) works perfectly... I made a pre version upgrade (1.14 - 1.16) and from 1.16 to 1.17 and the OST with data works.. thanks a lot for the help
            Is the scope of what is being worked on just generating the token? Is fetching and sending mail also implemented?
              leonlongoria
              Of course. We completely changed the package for mail from PEAR to Laminas-Mail which supports Modern Auth.
              I must be missing something. I'm on 1.17rc4 and this is what I'm seeing:
                leonlongoria
                fyi for this issue, our organization was doing something weird with our firewall and SSL certs. After going around that everything worked. thanks
                MontanaMac
                You have cURL issues on your server. Please follow the link displayed in the error to review the possible resolutions. this is outside the scope of osTicket software.
                margol
                I have no idea why; I am unable to replicate this..
                Are you using a test application? Are you sure you set the token expiration to a long period of time?
                  update: so the curl error was because of having "organizations" in the urls, changed them to "common" and now it appears to do nothing when saving the config, it just dumps me back to the login screen of the ticket system.
                    MontanaMac
                    Then that most likely needs you don’t have URL Rewriting enabled on your web server. Or maybe wrong endpoints. You need to go to app reg, click the app, click Overview, and click endpoints. You need to use the first two URLs (Authorization v2 and Token v2).
                    We have a test app on 17 RC4
                    I didn't change token expiration yet, but today morning I noticed:
                    • mails from Inbox didn't fetch
                    • one of ticket had a time of 'last Update' about 02 AM
                    • token are valid IMAP and SMTP
                    So I made:
                    • go to AOuth2 MS Remote Mailbox, IdP config and click on 'Submit'
                    • and that same Remote Mailbox disable 'Email Fetching' and click 'Save Changes', next enable 'Email Fetching' and click 'Save Changes'
                    After that mails fetch from Inbox.
                    Conclusion,
                    • why mails won't fetch byt one of ticket was update
                    • witch my actions cause fetch emails from Inbox
                      margol
                      Sounds like you need a cron job to automatically poll emails. Then each time it fetches it will update the tokens.
