osTicket (v1.10.1) ; Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/7.2.5 ; Mysql 5.5.60
After some changes on the configuration from scp login, the graph no longer shows the tickets and i don't know the reason. i tried to insert new ones, to transfer them but nothing. what must be checked and verified?
In particular it indicates NaN on the Y-axis, while on X- axis it shows the dates not in the system default format.
not even by entering: "default local settings" on "Date and Time Format" under system page
Thank you
    I give you more details.I don't' know how to preceed. Thank you very much
    I created a ticket and with my surprise the chart is back now. Remains the problem of "response times", which it's always to zero.
    a year later
    salvi Ciao, poi hai capito come hai risolto?
    I have the same problem
    @daw3b then you should upgrade. 1.10 is end of life and very out of support.
