I believe that if you are using SSL:// that port 25 is wrong.  Try 465.
solucionado, toda la configuracion aplicada esta bien, el problema era un servicio de linux
    21 days later
    ¿Qué servicio? Es que tengo el mismo problema D:
    2 months later
    Disculpen porfavor me piodrian decir como se soluciono el error ... por que por mas que busco no encuentro la solucion. Gracias.
    6 months later
    tengo el mismo problema, cual es la solucion.. gracias
    Offtopic, but please keep the language in English, so non-spanish speaking guys like me don't need to use a translator all the time - I am also not writing in German here, but I could, which would not be really helpful I guess, so: Vielen Dank und schöne Grüße.
    5 days later
    i have this troublefailed to connect to ssl://smtp.gmail.com
    @[deleted] please start your own thread.PHP error log?version of osTicket?your setup?SELinux?
    9 days later
    Solucionado... tengo instalada la version 1.9.4-rc2 con el correo de gmail y al crear un ticket no me llegaban las alertas a mi correo, la solucion es tener instalado un gestor de correo smtpPara windows instalar Mail Direct 2.6http://www.ocloudsoft.com/downloads/Para ubuntu 14.04sudo apt-get install postfix
    5 years later
    This thread is from 2013.
    Please do not be a necromancer.
    Killing Zombie thread with a head shot.
