sabarish So you just need to setup trigger actions in Zabbix to send emails to your osTicket email address.
Error in integration with zabbix
AdamDempsey
And i try one method for connecting with OSticket:
1.In mediatypes i had created email and i test, its shows like login denied,
2.And aslo i created another one in script and i test , its shows like permission denied but i checked it had permisson.
shall i share the screenshot of media types n zabbix.
sabarish If you're having issues getting Zabbix to send emails I suggest you check their documentation or forums.
This isn't an osTicket issue.
AdamDempsey
I had try it method but it not working
It looks like Gmail isn't allowing you to relay for some reason. In this case it appears you will need to set SMTP server port
to 587
, set Connection security
to either STARTTLS
or SSL/TLS
, set Authentication
to Username and password
, input your email's username and password, and retest. This is not an osTicket issue so I'd highly recommend reaching out to Hosting/Zabbix provider for further assistance.
Remote mailbox - In Authentication what should i config in here
sabarish
This appears to be a Gmail account, so I'll recommend following our guide here. You'll need the OAuth2 plugin from here.
We do not have any 3rd party integrations. The only way you can accomplish this is if Zabbix can send an email to an email address you configure in osTicket and then fetch that mail to create Tickets. Or utilize the API and have Zabbix send an API request with data to create Tickets. The caveat is with API you cannot update existing Tickets only create new ones so it’d be best for email integration.
We have guides below that can help you with this:
If you need further assistance contact us for support options:
Through existing email we can create or raise a ticket ??
Please anybody give me solution for this error .
You can’t use Private IP addresses.You must either use a valid Domain with HTTPS -or- use localhost over HTTP.
please tell me the process of this method
I linked the documentation above. The documentation explains everything step by step. For the Redirect URI you will need to use localhost if you only have HTTP or a valid domain if you have HTTPS.
there is anyother process for integrate with zabbix
i had done the step of the documentation but its indicates the error like google account authorization failed
