I have seen that solution in a previous discussion but it does not solve my problem.
Protocol required while setting SMTP server
Set Authentication to NONE, Status to Disabled, Save Changes, Status to Enabled, Authentication to Basic, configure auth, Save Changes.
Facing same error on the following the Authentication to NONE, Status to Disabled, Save Changes, Status to Enabled, Authentication to Basic, configure auth, Save Changes.
Refresh the email settings page, then follow steps
Status to Disabled,
Save Changes,
Status to Enabled,
configure auth,
Save Changes.
Thank you, after retrying today it worked !
Hey
how to set up basic authentication ?
KevinTheJedi please help if you know
Configure Hostname + Port, set Status to Disabled, set Authentication to None, click Save Changes, set Status to Enabled, set Authentication to Basic, click Config, add auth details, click Update, then click Save Changes.
KevinTheJedi from whare i can find auth details?
I am basically new to osticket !!
KevinTheJedi or is there any way to add users with password ?
And batch register user from guest
You appear to be talking about User registration which is completely off-topic here. This thread is about configuring a System Email for outbound mail.
Please start your own thread.
KevinTheJedi i tried to add email and password in basic configuration but it did not work !!
KevinTheJedi sorry i am not in office now, i I'll share once i get there.
Btw i am using gmail imap and smtp.
Then you need Modern Auth:
