ramrajone
  1. Linux servers automatically manage daylight saving.
  2. Yes, all PHP modules are installed & updated.
  3. I've had this issue with OSTicket for many years now.
  4. For some reasons beyond my understanding, if I set the timezone in OSTicket as Asia/Kolkata the delta is 2.5 hours. Hence I had to setup the timezone in OSticket to Europe/Athens
I believe the issue is with the code which the developers need to fix & I believe this is a good starting point for the developers....
    If the developers fix the code to understand IST as Asia/Kolkata, this issue will be fixed.
    2 months later
    Yeap I am also facing the same problem ... Need a quick fix for this and hope for early resolution
      Facing the same issue.. In the DB,time is proper.. Issue is only with the displaying in the OSTICKET Frontend.
      @rsclmumbai @hemanthnalluri
      The problem is actually with PHP's native timezone_name_from_abbr() method. When passing 'IST' to this method it returns 'Asia/Jerusalem' like we see in all these cases. Seems like this needs to be addressed on their level. I can create a patch to temporarily return 'Asia/Kolkata' instead but this is only a bandaid instead of a permanent fix.
        KevinTheJedi The problem is actually with PHP's native timezone_name_from_abbr() method. When passing 'IST' to this method it returns 'Asia/Jerusalem' like we see in all these cases. Seems like this needs to be addressed on their level. I can create a patch to temporarily return 'Asia/Kolkata' instead but this is only a bandaid instead of a permanent fix.
        @KevinTheJedi
        If you modify the code to:
        timezone_name_from_abbr($xxxx,$offset);
        It will work fine. I have tested this.
        Either the user will have to set the offset.
        Where is OST getting abbreviated timezone from?
        Can OST rely on full timezone instead of abbreviated tz?
        @rsclmumbai
        The abbreviated time zone is coming from MySQL (@@GLOBAL.system_time_zone).
        I will get back to you on the exact reason why we translate the abbreviations to full names.
        For me, SELECT @@global.time_zone shows "SYSTEM" & not IST
        This brings me to the command echo date_default_timezone_get(); and it shows "Asia/Kolkata"
        I'm following this thread on stackoverflow:
        https://stackoverflow.com/questions/2934258/how-do-i-get-the-current-time-zone-of-mysql
        Would it be better to use the timezone selection by the user so get past this issue in the simplest possible way, without having to rely on external parties like MySQL or PHP etc?
          2 years later
          kalepranali044 I had to tweak the time zone to match the timezone of my users.
          My users are in IST time zone (+5.30) but I had to select ""Athens"" at the timezone for the time to match accurately.
          HTH
