Setting a externel task scheduler in Ubunutu 18.04 step by step.
so from now onward the tickets get generated will show me in IST time. Right. But still it shows Asia/Jerusalem. I want to change it to Asia/ Kolkata.
Below are the screenshots that i have made to Asia/Kolkata for admin as well as agent.
Please help me to change Asia/Jerusalem to Asia/Kolkata.
There should be a change in include/class.timezone.php
I've run into this issue when using Indian Standard Time IST. PHP interprets it as Israel Standard Time.Equivalent +5.30 tz is Sri Lankan Standard Time SLST which is not detected by PHP. So I had to use a dirty modification to include/class.timezone.php174 return 'Europe/London';175 }176 // Override IST to India Time.177 if ($TZ === 'IST') {178 return 'Asia/Kolkata';179 }180 // Forbid timezone abbreviations like 'CDT'181 elseif ($TZ !== 'UTC' && strpos($TZ, '/') === false) {182 // Attempt to lookup based on the abbreviationLeaving this here just in case this is not fixed and someone runs into this issue and could not find a similar timezone to switch to.
I dont know how to do it. Just refer and tell. I refered it in one of your forums by searching OSTicket v1.10-stable Time issue.
cgi.fix_pathinfo "1" is recommended if AJAX is not working. I have change it to '1' but still show thw error.
While i was changing my manager in department . Its taking time and got crash. See the screenshots.
The query is not working.
- Now a new problem arised. Cron fetches mail but doesn,t generate new tickets and doesnt send auto response or auto reply.
- And there is some issue with the department tab whatever changes i am making it gets crashes. I have changed my memory_limit to 1024m and max_time_execution to 300 in apache2/php.ini.
Apache error.log>>
[Fri Aug 16 15:20:16.581075 2019] [php7:error] [pid 20697] [client 10.200.234.107:58144] PHP Fatal error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 20480 bytes) in /var/www/html/osticket/include/class.orm.php on line 3474, referer: http://10.200.236.106/osticket/scp/departments.php?id=3
[Fri Aug 16 15:20:16.594188 2019] [php7:error] [pid 20697] [client 10.200.234.107:58144] PHP Fatal error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 20480 bytes) in /var/www/html/osticket/include/class.orm.php on line 3439, referer: http://10.200.236.106/osticket/scp/departments.php?id=3
[Fri Aug 16 15:20:16.610378 2019] [php7:warn] [pid 20697] [client 10.200.234.107:58144] PHP Warning: Unknown: Cannot call session save handler in a recursive manner in Unknown on line 0, referer: http://10.200.236.106/osticket/scp/departments.php?id=3
[Fri Aug 16 15:20:16.610433 2019] [php7:warn] [pid 20697] [client 10.200.234.107:58144] PHP Warning: Unknown: Failed to write session data using user defined save handler. (session.save_path: /var/lib/php/sessions) in Unknown on line 0, referer: http://10.200.236.106/osticket/scp/departments.php?id=3
please find the solution.
any solution team.???????????????????????????????????
amarnath [Fri Aug 16 15:20:16.581075 2019] [php7:error] [pid 20697] [client 10.200.234.107:58144] PHP Fatal error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 20480 bytes) in /var/www/html/osticket/include/class.orm.php on line 3474, referer: http://10.200.236.106/osticket/scp/departments.php?id=3
Your PHP is running out of memory. I would address that first.
You take care of that by changing the php.ini file, and upping the memory_limit
directive,
its already set to 1024m
still the department section lags and i cant make any changes.
error after increasing the memory limit
[Tue Aug 20 09:34:25.884696 2019] [php7:error] [pid 14935] [client 10.200.234.107:38328] PHP Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 20480 bytes) in /var/www/html/osticket/include/class.orm.php on line 3474, referer: https://10.200.236.106/osticket/scp/departments.php?id=3](http://10.200.236.106/osticket/scp/departments.php?id=3)
I got this error on gmail.
Unable to connect to the database — No such file or directory
http://:var/www/html/osticket/api/cron.php
Ref-Mid: BMAMEu2-oqYie-AAAAAAAAAAAAAAAAP6ml55Pg-@osTicketMailer
You have had more issues with this one installation than I have in the past ten years of setting up osTicket of various versions on various OSes.
Version of osTicket?
Version of PHP?
Webserver being used?
Are you running SELinux?
