PHP 5.6.40-5 and ubuntu14.04.1
[SOLVED] After Upgrade 1.10.6 to 1.12 tickets are not visible
Okay, PHP should be fine. Ubuntu 14 is EOL unless you've purchased Extended Security Maintenance, but this shouldn't affect osTicket much. Are you able to upgrade to 16 or 18? By default, this would give you a more up-to-date PHP version too.
What about MySQL version? Generally if 1.10.6 works fine then I can't imagine there'd be any other system settings that would cause issues, but maybe someone more knowledgeable than myself in this matter would have better advice ?
I have mysql Ver 14.14 Distrib 5.5.62.
I tried to upgrade to 16 or 18, but after upgrade when I login I get an error "csrf token is invalid". This is the main reason because I still on 14 .
It sounds to me like your agent account does not have access to the departments that the tickets are in. HAve you confirmed that you actually have access to the tickets in the ui ?
Hello, here you have, thanks in advance.
Try upgrading PHP to 5.6.
Glad to be of assistance. I'll close this thread, but please feel free to start a new thread if you have another question, problem, etc.
