Did you setup any teams?
[SOLVED] Tickets created from email have status = 0
Can you look at your ost_ticket table and see what the assigned dept_id or team_id is? Because the only time I have ever seen anything like this is when someone does not have access to the dept or team that they tickets are assigned to.
Status 0? There is no status 0.
Whats your Admin panel -> Settings -> Tickets -> Default Status set to?
I suppose that's the problem. I've updated status of a ticket via sql request.
And now it is shown in ticket list.
Do you have any ticket filters?
I've asked the devs to take a look at this thread.
I tested this with latest osTicket v1.11 and PHP v7.2 and I cannot replicate your issue. Really strange.
I did clean install of version 1.11.
The issue is not reproduced.
I will mark the post as solved.
I now have this on a fresh install of 1.11 on PHP7.1 and getting errors from the cron job.
PHP Fatal error: APCuIterator::__construct(): APC must be enabled to use APCuIterator in /var/www/support.crm.direct/public_html/include/class.search.php on line 966
It seems that PHP7.x does not support ACPu and fakes it out with acpu.so. I fixed my problem by editing /etc/php/7.1/cli/conf.d/20-acpu.ini and commented out loading acpu.so so osTicket falls back to its built-in caching.
