I have news information about this problem. the real problem is that every time we put an image at the level of the ticket response the error is generated. Please help me to solve this problem, I need your help, I'm still looking.
    sipe I suppose if you are not running a stable release no support will be provided or guarantee.
    sipe
    can you try this
    https://github.com/osTicket/osTicket/commit/d8abe105ec04b7750fcd119bf79edb2b01808cd7
    edit: include/class.thread.php
    change from:
    function getClean() { function getClean() {
    return Format::htmlchars(Format::stripEmptyLines(parent::getClean()), true);
    To this:
    return Format::htmlchars(Format::stripEmptyLines(parent::getClean()), true); return Format::htmlchars(Format::html_balance(Format::stripEmptyLines(parent::getClean())));
    good evening, for my problem I just saw that the stable version of osticket v1.11 came out yesterday.
    But my problem is not solved. just that it does not send the error, its shows that the ticket has been sent but when I look in the created tickets it does not display. So the ticket is not created.
    Look at your ost_ticket table. Is the ticket there?
    Your response does not actually answer my question. Look at your database, specifically the ost_ticket table. Is the ticket there?
    • sipe replied to this.
      ntozier yes in the database, the ticket is created, but I do not see it when I go on the ticket page of osticket.
      Sorry for the inconvenience, thanks for all your interventions, the stable version of osticket v1.11 has solved my version v1.11.0-rc problem. After upgrading to stable v1.11, the problem is that after creating the ticket with the image in the response field, I was looking for the ticket in open tickets rather than closed tickets. While I closed the ticket
      It sounded to me like if the ticket is in the database then it was created and you just did not have permission t osee it... but looking in the wrong place makes sense too.
