What are the permissions on your PHP temp folder? [do they match?]
Waltervds
Run this command to apply permissions
sudo chown -R www-data:www-data /var/www/html/osticketLocaton
Waltervds
That command was for Linux Ubuntu
Which version of OS are you using?
it is Linux, but since it's hosted I don't see what version it is
Waltervds
Maybe you don't have permission to run commands, check it and change it via GUI or ask your hoster to change it for you
It should be set as: All folders should be 755 and all files should be 644
run this command to see which version of Linux you are using:
lsb_release -a
or
hostnamectl
both commands also give not found .
The strange thing is the folders that are created by the plugin all get 1355 where it seems to me they should get 755
