You mean in Agents => Roles => Limited Access (Agent A and B are in this Role) => Permissions ?http://prntscr.com/j9i8i8If I remove "Edit" they'll can't have access to the edit button and they will can't complete form at all. :(There is an another way to complete form than click on button edit ? Thanks !
I mean with the instructions i sent you on my first reply.Q: There is an another way to complete form than click on button edit ? forms can be added by help topics at ticket create and populated then.I dont know of any way to prevernt users from editing forms other than the removal of edit privs.
Ok so I think what I want is not possible yet. Maybe it could be an option that the osticket dev should integrate in the next release. Just for more details, I need this for a workflow. I would use it as workflow to create the access/permissions for our new employees. For example, a new employee is hired, the manager complete a form with the access needed and the ticket is assigned to IT, Quality Assurrance for validation etc... But during the workflow, the information put in a form need to be the same at the beggining of the workflow until the end. I hope this option will be integrate in the future release :)Thanks for your help !
Sounds to me like you are talking about tasks...
Is it possible to add form in tasks ?
I dont think that you can add forms to tasks ... but you can add custom fields to the Task Details form.
Hi,I didn't find how to add custom fields to the task. When I create task I only can add text but I can't add custom feilds or I'm blind and I don't see where is it.Just to be sure, you are talking about this, please see below :http://prntscr.com/j9t0naThanks !
Admin panel -> Manage -> Forms -> Task Details
Hi,Ok found it.Here I can add fields for Buil-in Forms named "Task Details" but I don't want to add fields in only one task.I would like create other "Task Details" forms and use each task details form for a specific task. For example :Task details form 1 => I use it for task 1Task details form 2 => I use it for task 2etc...Each task should have her own task details form. Is it possible ?Thanks !
6 months later
Consulta el Formulario de Detalles de la Tarea viene como formulario incorporado o lo tengo que crear personalizado?
y puede ser que aunque tenga marcado que me envie aviso de tarea vencida no me llegue el aviso por mail?
    mremersaro
    You might want to start your own thread. Since your post doesn't appear to have anything to do with this thread.
    Closing old thread.
