I use the translation from this website.. The one you are referring to! So that's not my problem then...
The mail fetching i solved with using an gmail adress. So unfortunately because the translation is not working i have to quit this.. Is there a possibilty to reinstall osticket without losing the data/configuration?
This is the website: http://support.liveatschool.nl/
when you first go on the site it is Dutch.. After you click open nieuw ticket, then it's english...
I do not think you are even following what ntozier is saying because with share mailboxes he provided instructions that have worked for others with these conditions. Also, have you downloaded the latest versions of the dutch language from osticket.com/download? Have you removed the old one and installed the new one? There is something you are doing to cause this, also your OSTicket has some modifications to it, are you sure you didn't change something to cause the translation to break from front page to the ticket section?
It looks like he is using some third party theme or other modifications, and yes he seems to be ignoring what @[deleted] has been telling him.
The mail problem is not the issue anymore... When using gmail it works..
yes is used a theme, but it worked a few weeks.. i really don't know what i changed that it does not work anymore... and yes is used the latest version.
But also in the admin panel sometimes it's dutch and when i click something it is English again.. I did not change anything on the admin pages with the source code... I removed the old NL.phar and uploaded the new one again. @ Synt4xError, u mentioned installing the language pack? If i put it in the  i18n folder it's showing it on the admin panel.. did i missed something with installing maybe?
found a way to extract the nl.phar! now it seems like its working!! Thanks for pointing that Synt4xError!! Strange that after uploading nl.phar i could choose NL and it worked for a while..
2 years later
Wow....can i say sorry for the Dutch? We are not all like that but when something says 'free' some of us kind of lose the grip on themselves. Topdesk is great! But it's not free :-( iTop is! More trouble!!!
Hope to be an addition to this forum as long as we can't pay it back in any other way. ;-)
9 days later
