Currently the only workaround is to create separate internal department(s) to whom all agents with that "limited access" have full access, so that the can see assigned and also closed/resolved tickets.
I still do not see the logic in not being able to see the tickets your department has closed.  We run multiple departments and we do not want the desktop, networking, and telco groups to see each others tickets.  Our departments work very hard and spend a HUGE amount of time documenting resolutions in each ticket.  But this is a waste of time as they can not go back and review resolutions to past issues necessitating them to re-invent the wheel each time instead of being efficient.  As a manager who reviews SLA's and time spent per ticket, I can't talk to individuals to see why it took x amount of time when I know the resolution to the issue was already documented when they can't see it.  This is very counter productive.
3 months later
Is there still no solution? Need this feature to..
a month later
Hello altogether,I changed the code in /include/staff/tickets.inc.php - in OST Version 1.9.9arrount line 80 ( not realy shure as my tickets.inc.php is very customized ) find this code:        .' AND status.state="open") ';and change it to :       .' AND (status.state="open" OR status.state="closed")) ';Now my agent can see (ONLY) his own closed Tickets.I'm still looking how to show the number of closed tickets.Will update this post as soon as I find a solution.cheers Claus
HI Claus,Great solution for seeing the tickets, but clicking on one of them gives me a "Access denied. Contact admin if you believe this is in error". Any workaround to get into the closed tickets?Thank you!
Ah, I got the solution (I think) from fear-n-ice here:Only using C_c_lohmar's code, and this one:Edit "class.ticket.php" in the "/.include/" folder:Around line 180, add/edit the following code://Staff has access to the closed ticketif ($staff->showAssignedOnly() && ($staff->getId() == $this->getStaffId()) )return true;That did it (hopefully!).  I'll post any errors for anyone else I come across.
Last update - this code appears to be throwing a fatal error in the PHP log... PHP Fatal error:  Call to a member function showAssignedOnly() on a non-object in F:\sites\osticket19\include\class.ticket.php on line 2255Any advice on what to change?
4 days later
Hi holodoctor1 ,Thank you for this feedback and your addition to this mod - I actually din't make a test opening a ticket with a restricted Agent.Regarding the fatal error - Have you also applied the suggested change around line 2252?if ($staff->showAssignedOnly())
$where = '(ticket.staff_id='.db_input($staff->getId()).' AND status.state="closed")'
I still looking for the file that needs to get edited, to show the amount of closed Tickets in the Table Header. If any one has helpful information?Claus
2 months later
+1 for this feature, I think for many users this would be extremely useful because closed tickets are sometimes required for reference and the workaround of creating a separate department is not really ideal.
10 months later
Subscribing. Maybe someone made this feature for v1.10-rc.3, because it is the only we miss in this app. Our stuff need to see tickets closed by them.
3 years later
For osTicket (v1.11.0-rc1) you can change the following file: include/class.staff.php
method: getTicketsVisibility()
line:
$visibility = Q::any(new Q(array('status__state'=>'open', $assigned)));
to
$visibility = Q::any(new Q(array('status__state__in'=>array('open', 'closed'), $assigned)));
