Hello,I upgrading osticket from 1.9.2 to 1.9.4 and the upgrade was ok, without errors. I log into the Admin control panel and it displayed as you see on image1.png. I tried to install a zero installation (no upgrading)  and occurs the same.I don´t have any idea what happens.  :( Does anybody has this problem?Thank you and Happy new year 2015.
Error?broken image.Please help us to help you by reading and following the posting guidelines located in this thread: Please read before requesting assistance.  The more information you give us the better we will be able to assist you. Thank you.
8 days later
Hello ntozierI don´t know what happened with my image, here is again the image, I hope this time you could see. Sorry for don´t give more information before, looking for a solution to my problem I found someone who had the same problem as me,  this is the post TravisTubbs wrote:http://forum.osticket.com/d/discussion//header-and-footer-not-loading-prevents-styles-and-scripts-from-loadingcasually I have the same host provider (media temple) and the same PHP V.x FastCGI and I made the change he applied and this fix the problem.I hope if someone has the same problem this could helps.Thanks.
Great!  I'm glad that you got that sorted.I'll close this thread and mark it resolved.Please start a new one if you have another question.
