Hii got a sqldump from my database used by osticket 1.6ST version but i delete the whole system and this morning i installed the 1.9 version, do you know if its possible to use the old database with the new version 1.9?
I don't think you can since the old database more than likely would have a different structure than v1.9The conversion should be able to make these database adjustments as needed.
You can in fact use the 1.6 database.the 1.9 version should upgrade it for you. I would save the back up though just incase you run into issues with the upgrade. You would simply need to change the ost-config.php file to point to the old database (and username/password), and then log into the staff side. It should prompt you to upgrade.
Hi Ntozier:i tried to update from 1.6ST to 1.9.1 several times, clean installations with my db and always get the error:DB Error #1054and: Upgrader Error------------------------------------If i install 1.6ST with a clean database and the upgrade to 1.9.1 i got no problems.Also i have zero attachments in folders.
also i tried this:I found this in another thread:1.6ST (Current Version) => 1.7.0 => 1.7.7 => 1.8.0.4 => 1.8.1.2but the same error appears when i upgrade to 1.7.0
