It all depends on what the key from the db is and the IIS setup. Not all setups are the same so yours could very well not be case sensitive. I just know the majority of IIS setups that I’ve dealt with are. Anyways, the key from the db is always the correct casing. So whatever the first character of the key in the db is should be the folder it’s stored in.
