mzgela
What's the specific error? Like how do you know it's in bootstrap?
Are you sure your task is running as the correct user? You need to run it with a user that has appropriate permissions (usually IIS user).
13 days later
Bcs I was writing output log in lines of codes and in bootstrap file just out... I dont know what to do anymore -.-
Even if I run php command on api/cron.php not working.
Also made bat file C:\Program Files (x86)\PHP\v7.4\php.exe -f C:\inetpub\wwwroot\osTicket_test\api\cron.php but nothing 😛
I put all permissions for all users 😛
    mzgela
    Then I can only suggest upgrading PHP and osTicket (and any plugins) and retest. Since you are using an outdated and unsupported version we cannot assist.
    I upgrade on 1.18. version and now I can't find cron.php file that I need to put in script?
    I get this when I start cron.php on version 1.18.
    Deprecated: Optional parameter $namespace declared before required parameter $key is implicitly treated as a required parameter in D:\xampp\htdocs\osTicket\include\class.config.php on line 198
    Deprecated: Return type of BaseList::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 101
    Deprecated: Return type of BaseList::count($mode = COUNT_NORMAL) should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 106
    Deprecated: Return type of ListObject::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 220
    Deprecated: Return type of ListObject::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 198
    Deprecated: Return type of ListObject::offsetSet($offset, $value) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 207
    Deprecated: Return type of ListObject::offsetUnset($offset) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.util.php on line 227
    Deprecated: Return type of ModelMeta::offsetExists($field) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 242
    Deprecated: Return type of ModelMeta::offsetGet($field) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 236
    Deprecated: Return type of ModelMeta::offsetSet($field, $what) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 239
    Deprecated: Return type of ModelMeta::offsetUnset($field) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 245
    Deprecated: Return type of QuerySet::getIterator($iterator = false) should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1565
    Deprecated: Return type of QuerySet::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1596
    Deprecated: Return type of QuerySet::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1599
    Deprecated: Return type of QuerySet::offsetSet($a, $b) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1605
    Deprecated: Return type of QuerySet::offsetUnset($a) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1602
    Deprecated: Return type of QuerySet::count() should either be compatible with Countable::count(): int, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1371
    Deprecated: Return type of CachedResultSet::offsetExists($offset) should either be compatible with ArrayAccess::offsetExists(mixed $offset): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1743
    Deprecated: Return type of CachedResultSet::offsetGet($offset) should either be compatible with ArrayAccess::offsetGet(mixed $offset): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1747
    Deprecated: Return type of CachedResultSet::offsetSet($a, $b) should either be compatible with ArrayAccess::offsetSet(mixed $offset, mixed $value): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1754
    Deprecated: Return type of CachedResultSet::offsetUnset($a) should either be compatible with ArrayAccess::offsetUnset(mixed $offset): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 1751
    Deprecated: Return type of ModelInstanceManager::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2002
    Deprecated: Return type of CallbackSimpleIterator::current() should either be compatible with Iterator::current(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2046
    Deprecated: Return type of CallbackSimpleIterator::next() should either be compatible with Iterator::next(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2051
    Deprecated: Return type of CallbackSimpleIterator::key() should either be compatible with Iterator::key(): mixed, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2036
    Deprecated: Return type of CallbackSimpleIterator::valid() should either be compatible with Iterator::valid(): bool, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2040
    Deprecated: Return type of CallbackSimpleIterator::rewind() should either be compatible with Iterator::rewind(): void, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2031
    Deprecated: Return type of FlatArrayIterator::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2076
    Deprecated: Return type of HashArrayIterator::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.orm.php on line 2099
    Deprecated: Return type of BaseMessageStorage::getIterator() should either be compatible with IteratorAggregate::getIterator(): Traversable, or the #[\ReturnTypeWillChange] attribute should be used to temporarily suppress the notice in D:\xampp\htdocs\osTicket\include\class.message.php on line 186
    Warning: ini_set(): Session ini settings cannot be changed after headers have already been sent in D:\xampp\htdocs\osTicket\bootstrap.php on line 19
    Warning: session_cache_limiter(): Session cache limiter cannot be changed after headers have already been sent in D:\xampp\htdocs\osTicket\bootstrap.php on line 21
      mzgela
      None of these are errors. You simply need to configure your PHP to ignore warnings/deprecations and only log real errors. Then you need to make sure display_errors and display_startup_errors are both disabled in your PHP INI and your bootsrap.php file.
      But I still got nothing in logs -.- like I never start cron.job
      It's not even work if I run from client, I deleted condition for cheking if is Client in cron.php file...
      and one thing that I figure is that my auto cron working on 1.14. but not working on 1.18... I dont know what is with this osticket versions
      You said that you setup
      Kevin said to update PHP.
      Did you?
      Did you then go and change the path to PHP in the path above?
        ntozier
        Yes I upgrade the PHP and osticket version, setup emails, enable fetch emails. Auto cron working, but when I start cron over php cmd not working. In logs I get cron job executed but ticket not created.
        I managed to get this working, with version 1.18. i needed to put ssl:// in mail settings because I am using IMAP+SSL
        You can close this
          mzgela
          You shouldn’t normally have to manually type ssl://; however I’m glad you figured it out.
