alcero
Upgrade to v1.17.3, install the latest build of the OAuth2 plugin, get a new token, and you should be good.
The Access Token will always expire in 1 hour by default. We then use the Refresh Token to refresh the Access Token on expiration which will give a new Access Token, new Refresh Token, and new expiration time. There was however a previous bug where we weren't updating the Refresh Token so about 90 days later it will stop working and you have to manually get a new token. With v1.17.3 and new build of OAuth2 plugin the bug was addressed. Once you do the above, moving forward, the tokens should only stop working when the Client Secret expires OR something from MS end invalidates the tokens (usually very rare).
    KevinTheJedi I upgraded ost and plugins like you mentioned
    How do I get new token?
    I deleted the token
    when I press submit
    I get this
    "No input file specified."
    Thanks
      alcero
      You can google that error to see what's causing that. Nothing from the software though. Could be PHP misconfigurations/restrictions, URL Rewriting not enabled on the webserver, incorrect URLs being used, etc.
      alcero
      Typically this is due to URL Rewriting not being enabled on the webserver. What webserver are you using? You never posted a screenshot of your Admin Panel > Dashboard > Information page so we don't know what your environment looks like.
      Connection worked now
      But big delays on opening tickets when we send email to support email. Is that normal? We have set fetch to 1min
        7 days later
        I did
        Now it's only pulling email when I log in to the system
        Seems like it's going to sleep when no one is logged in or visiting our support site
          alcero
          Then your cron job is not working or you don't have the setting enabled in osTicket. Go to Admin Panel > Emails > Settings, look for Email Fetching, check the box next to Enable, uncheck the box next to Fetch on auto-cron, and Save Changes. Now go set your Log Level to DEBUG, run the cron, and check the system logs to see if it added a cron job entry saying it executed.
            alcero
            That’s the one. Then it appears your cron job statement is not correct or you didn’t set the Log Level to DEBUG. Please contact your host for the proper path to the correct PHP version.
            alcero
            Well you can enable it temporarily so email still fetches. Then you can disable it once the cron is actually working. It's only needed if you can't setup cron for some reason.
              alcero
              I’m assuming the PHP path is incorrect. Typically they have multiple versions of PHP installed and they have special paths. Contact your hosting provider for the correct PHP path to use.
              But when I log in osticket, the fetch works.
              Is tgis normal? Is it still cron issue?
              Do you know what command needs to be set in cron?
              Command
              /usr/bin/php -q /home/custom
              Is this good?
                alcero
                That's because it's using Auto-cron which is a crutch really. Yes, still means cron job isn't working properly. As I mentioned above: Contact your hosting provider for the correct PHP path to use.
                It's typically:
                php /path/to/osticket/api/cron.php
                However as I said above you are using a hosting provider and each provider has their own specific setup. You need to contact your host for further assistance.
