Thanks will let you know how I get on
got ssh access and ran got here so far
-jailshell-4.2$ whereis php
php: /usr/bin/php /usr/lib64/php /usr/local/bin/php
-jailshell-4.2$
    5 days later
    I know this sounds silly but am still not sure what to do next ?
    i cannot seem to browse to osticket folder
      btssn
      What do you mean? You can’t cd? Every major Linux system has this command available.
      btssn
      It doesn’t appear to be hosted from public_html then. Maybe ask your hosting provider or site/server admin where the site files are hosted? I see you have CPanel, maybe try accessing the File Manager through CPanel and see what directory the site is hosted from and then use that path on the command line.
      I’m sorry but I’m unfamiliar with your setup as it’s self-hosted so I can’t give you an exact path.
      Looks like i am logging to other account will contact hostgator
      6 days later
      So hostgator sorted out ssh on sub domain
      see attachment
      so here is output now i know why i did not become software programmer
      which path do i type ?
      btssn
      Something might be failing as it’s supposed to return something like "Migrated X Files". You can edit your bootstrap.php file and set both display_errors and display_startup_errors to 1 and rerun the command to see if it outputs any errors.
      btssn
      Actually first try lowering the "--limit" to like 10 and see if it outputs something. If not then do the above.
