Hi I'm trying to configure the oauth2 plugin but I'm having this problem as per the screenshot
Error Oauth2 plugin
For SMTP use Same as Remote Mailbox
if you already have it setup for the Remote Mailbox tab.
Otherwise you'll have to look for any related errors in your logs (general server logs, webserver error logs, PHP error logs, MySQL/MariaDB error logs, osTicket System Logs, Browser Console logs, etc.).
If this is for an email that already existed before oauth2. you may have to delete and re add. That's what I had to do.
it-law-man Okay, now go. Go to the end of the configuration I get this message
No input file specified.
What could it be?
fixpc82
Do you have rewrite enabled for apache?
You will also have to add "AllowOverride All" to the main Apache config
