Sorry, there is the information request.
The size of image that I put in template
Hello any solution?
@ppark
I am unable to replicate the issue using v1.15.2, Apache, PHP 7.4, and MySQL 8.0. I would recommend upgrading to v1.15.2, removing the image, and re-adding it.
It´s the same thing, now when I insert logo and do a Save, the image disappears.
I believe this is the same as:
ok thank you
We have the same issue here. Is there any fix available?
@Towerplease scroll up to the post with the fix up two from your comment.
ntozier I'm not sure, but i cannot see any fix in the post. Just another description of the issue. I am currently running the following config/server:
See this:
ntozier Yeah, well. Kevin wrote: "This issue is due to a deeper underlying issue so it's on hold until we can come up with a fix.
Cheers." Guess it just needs some time to come up with an update to fix the issue then?
