Any news ?
Thanks Marcello
@marbet
You will need to post a screenshot of the ticket that does not show the buttons. Like @ntozier said you most likely don't have access to that Ticket's Department or it has been transferred to a Department in which you don't have access to. If it has been transferred outside your Department but your Department maintains Referral access it will give you Read-Only permissions for that ticket.
    KevinTheJedi is the second post and the third post indicated that I have full access to Support Dept.
    @marbet
    But I can't confirm that the ticket not showing those buttons are under the same department...we would need a screenshot of the ticket's header that isn't working to confirm the Department is in-fact Support.
      25 days later
      ntozier Sorry ntozier,
      do you have any new or solutions ?
      Regards
      Sorry Kevin,
      is it not clear what do you mean ?
      The problem remains and there seems to be no solution. Regards
      @marbet
      So are you saying you can view the ticket but when you do it doesn’t show the thread? If so you need to check all error logs for related errors (server logs, apache error logs, PHP error logs, MySQL error logs, osTicket system logs, browser console logs).
        [Fri Dec 04 11:39:37.260107 2020] [php7:warn] [pid 26710] [client xxx.xxx.xxx.xxx:2828] PHP Warning:  strtotime() expects parameter 1 to be string, object given in /var/www/osticket/include/class.lock.php on line 66, referer: https://help.xxxxxx.info/scp/tickets.php?id=66
        [Fri Dec 04 11:40:07.681542 2020] [php7:error] [pid 26816] [client xxx.xxx.xxx.xxx:2844] PHP Fatal error:  Uncaught ObjectNotUnique: One object was expected; however multiple objects in the database matched the query. In fact, there are 2 matching objects. in /var/www/osticket/include/class.orm.php:1363                                      \n
        Stack trace:\n
        #0 /var/www/osticket/include/class.orm.php(606): QuerySet->one()\n
        #1 /var/www/osticket/include/staff/templates/thread-entries.tmpl.php(37): VerySimpleModel::lookup(Array)\n
        #2 /var/www/osticket/include/class.thread.php(415): include('/var/www/ostick...')\n
        #3 /var/www/osticket/include/staff/ticket-view.inc.php(773): Thread->render(Array, Array)\n
        #4 /var/www/osticket/scp/tickets.php(560): require_once('/var/www/ostick...')\n
        #5 {main}\nthrown in /var/www/osticket/include/class.orm.php on line 1363
        Edited By - TheJediKev
        @marbet
        Ahh, you need to login to the database, go to the ost_thread_entry_email table, and look for records with duplicate thread_entry_id values. You need to figure out which one is not needed and delete it.
        SELECT
            `thread_entry_id`,
            COUNT(`thread_entry_id`)
        FROM
            `ost_thread_entry_email`
        GROUP BY `thread_entry_id`
        HAVING COUNT(`thread_entry_id`) > 1;
        Once you do this you should be able to view the ticket thread. If you run into the same error, repeat the steps until there are no duplicates.
