Email piping still not working this is getting very frustrating as any emails sent to tickets email address need to be updated manually to ticket.
Any help and advice on next steps would be appreciated, i have sent them another email with link to this page lets see what they come back with ?
9 days later
Hostgator Reply
Hello
Thank you for providing further information and allowing us to continue troubleshooting this matter. Web Advisor II, I've had the pleasure of reviewing your case and I'll be happy to assist you today
I attempted to call you today prior to sending this email, but unfortunately was only able to leave a voice mail. The failed loading error suggest that the the Ioncube module was not recolonized by the osticket. To resolve this error, I have changed the Addhandler rule in the ticket directory /home1/btssn/public_html/ticket. I have commented out the suphp path to allow for the default path on the server. This also required disabling the custom php.ini file. As of now, the current version of PHP 7.1 has been switched to EA4. For confirmation, please visit https://www.btssn.co.uk/ticket/phpinfo.php
For testing, please use ???@gmail.com. I hope I was able to assist you with your concern. If I have misunderstood your what you are requesting, I sincerely apologize. I am strictly going based off of the information provided to me. Please correct me if I have not addressed your concern accurately.
They have managed to create 2 tickets in osticket however when i tested using my email address i am still getting error so i sent email as below;
Hi ???
Thank you for your detailed reply, as i can see you managed to create 2 tickets 0510 and 0511 using email piping with email address ???@gmail.com, i have tried to test email piping with ???@btssn.co.uk with no success i have deleted and added new forwarder in cpanel folllowing guide here https://docs.osticket.com/en/latest/Getting%20Started/Email%20Piping.html?highlight=email%20piping#local-piping
Something has happened on server end as osticket email piping was working fine and all tickets were being updated via email.
The test email sent to ???@btssn.co.uk is delivered to email address however is not pipe into osticket and error as below:
This message was created automatically by mail delivery software.
A message that you sent could not be delivered to one or more of its
recipients. This is a permanent error. The following address(es) failed:
pipe to |/home1/btssn/public_html/ticket/api/pipe.php
generated by ???@btssn.co.uk
local delivery failed
The following text was generated during the delivery attempt:
------ pipe to |/home1/btssn/public_html/ticket/api/pipe.php
generated by ???@btssn.co.uk ------
Failed loading /opt/ioncube/ioncube_loader_lin_5.6.so: /opt/ioncube/ioncube_loader_lin_5.6.so: undefined symbol: zend_execute_ex
Failed loading /opt/php56/lib/php/extensions/no-debug-non-zts-20131226/ZendGuardLoader.so: /opt/php56/lib/php/extensions/no-debug-non-zts-20131226/ZendGuardLoader.so: undefined symbol: zend_execute_ex
  Reporting-MTA: dns; merkur.websitewelcome.com
Action: failed
Final-Recipient: rfc822;|/home1/btssn/public_html/ticket/api/pipe.php
Status: 5.0.0
I await your reply to look at matter further if you require login to ostciket i can arrange that as well, many thanks
Regards,
So in summary It looks like they have resolved some issues not all
    btssn
    Can you take screenshot of your email settings for osTIcket?
    The error: it could be routing within cPanel their support said they deleted and recreated the account
    "A message that you sent could not be delivered to one or more of its
    local delivery failed"
    Hi Quick update
    We are one stage further see below;
    My name is ? and I am a Web Advisor II here at HostGator. I have reviewed your case 19778708 regarding osTicket on the cPanel of btssn.co.uk.
    First and foremost, I would like to apologize for any inconvenience that this issue may have caused you and your business. Secondly, I would like to apologize for the delay in our response time, the ticket queue has been higher than usual and has caused some delays. I did some investigating and I found that updating the PHP version the forwarder/piping is using resolved the issue.
    I tested the current pipe that is set up and received the same error:
    btssn@btssn.co.uk []# test | /home/btssn/public_html/ticket/api/pipe.php
    I created a new pipe added '/opt/php71/bin/php' at the beginning of it to force it to use PHP 7.1, once this was done, it was different results:
    btssn@btssn.co.uk []# test | /opt/php71/bin/php /home/btssn/public_html/ticket/api/pipe.php
    (400) Email parse failed []
    (400) Unable to create new ticket: validation errors:
    user: Incomplete client information
    5: Issue Summary is a required field
    6: Issue Details is a required field
    (416) Request failed - retry again!
    The error that it received with PHP 7.1 is only due to missing information and not PHP related. It looks like this may work.
    I left the forwarder/pipe you had there since I did not want to remove it without your approval. If you are able to confirm that the forwarder I created now works, then please remove the forwarder you had setup.
    So the email piping is working now however i am still getting Mail delivery failed: returning message to sender message even though message has been added to osticket
    Here is my reply below to hostgator below:
    Hi J?,
    Many thanks for your help and support in resolving issue, although you have managed to fix email piping issue and messages are being added to osticket now, i am still receiving an error email even though email piping has worked correctly and i have deleted old forwarder.
    Here is error email below:
    pipe to |/opt/php71/bin/php /home/btssn/public_html/ticket/api/pipe.php
    ------ pipe to |/opt/php71/bin/php /home/btssn/public_html/ticket/api/pipe.php
    Action: failed
    Final-Recipient: rfc822;|/opt/php71/bin/php /home/btssn/public_html/ticket/api/pipe.php
    Status: 5.0.0
    I am aware of this link here
    https://docs.osticket.com/en/v1.14.1/Getting%20Started/Email%20Piping.html
    Where it mentions to update php,ini and exim.conf
    Hope this helps and we can finally resolve issue although we are 90% there
    Just relaised now have these api error messages
    btssn
    On this screenshot, you also have Default MTA set to PHP mail function, normally it's SMTP unless you have configured PHP
      ramrajone
      That is the only option i have and sending out test message is fine no errors only when email piping occurs there is error
        btssn
        Take a look at the API error, when you mouse your mouse over, it will give you details, something is not set up correct or missing, it could be PHP, web server, etc...
        Update time,
        So hostgator have fixed mail delivery error the only issue i now see is api errors
        see attached screenshots
        my next step will be to give hostgator a login to ticket system so they can check and fix any help or advice would be appreciated
          Hi Done thanks and cleared api logs all looks good see screenshot below
          Now the only issue i have realised if i send email from internal domain @btssn.co.uk
          i get Mail delivery failed: returning message to sender
          error as below;
          pipe to |/opt/php71/bin/php -q /home/btssn/public_html/ticket/api/pipe.php
          generated by ti@btssn.co.uk
          ------ pipe to |/opt/php71/bin/php -q /home/btssn/public_html/ticket/api/pipe.php
          generated by t@btssn.co.uk ------
          Action: failed
          Final-Recipient: rfc822;|/opt/php71/bin/php -q /home/btssn/public_html/ticket/api/pipe.php
          Status: 5.0.0
          Is this because email used to send is on same domain as email i sending to, if i use my yahoo no errors occur and after adding api key no more error messages occur 🙂
