It's not a bug that I am aware of.
It could be an issue with running an unsupported version of PHP (which is why I asked what version you were running).
If you don't want to upgrade that's your decision. The version you are running is from 2017 and there have been a lot of Performance and Security fixes added since then. Just know that you are running and end of life product and will not be able to get support on it.
osTicket requires PHP 5.6 to 7.3.
@ntozier
@ramrajone
Since yesterday, i m tryning to upgrade but wamp still down , I have some php extensions that still down.
I have noticed that in php.ini, the zend_extension is set to :
zend_extension = "c:/wamp/bin/php/php7.2.25/zend_ext/php_xdebug-2.2.5-5.5-vc11.dll"
But in the zip I don't have this folder zend_ext and neither this dll: php_xdebug-2.2.5-5.5-vc11.dll
Any help please
    SAYEH2
    Which zip folder are you referring to?
    Can you take a screenshot of your errors and /scp/system.php
    I assume you have restart web server after making changes to PHP
    I choose php 7.2.25 from php.net and it contains the folders/files in the attached screenshot (php7.phg).
    I don't have errors except that wampserver icon still orange and you can also find system.php
    Of course I have restrated the web server.
    If you installed wampserver from wampserver.com then you would want to read their upgrade procedures for upgrading PHP. I do not use their "solution" and have always installed my webserver, database and PHP packages separately.
      4 years later
