Mailer error php
nop, the error still appears...
PHP error log location is specified in your php.ini.
Mailserver logs would be very dependent on what mail server software that you are running.
ntozier in php error log say this
"[28-Nov-2019 14:13:20 UTC] PHP Warning: Use of undefined constant EmailTemplateGroup - assumed 'EmailTemplateGroup' (this will throw an Error in a future version of PHP) in C:\inetpub\wwwroot\include\staff\tpl.inc.php on line 4
[28-Nov-2019 14:16:08 UTC] PHP Warning: mail(): SMTP server response: 503 5.5.2 Need rcpt command in C:\inetpub\wwwroot\include\pear\Mail\mail.php on line 156
I do not understand why the emails I send with the "diagnostic" tool if you send them.
as well as the mails of "auto-response of new ticket"
but those that do not arrive are the "new ticket notice"
Still waiting on the Mail server error logs.
Feel free to post any pertinent errors here (and feel free to redact your domain).
ntozier i not see any error
[2002:a0a4:22c:]:55400,[2002:a0a4:22c]:2525,>,XPROXYFROM SID=08D76908C6D356B3 IP=160.16.xxx.xxxx PORT=64686 DOMAIN=domain.gov.ar SEQNUM=1 PERMS=1077 AUTHSRC=Anonymous,
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,304,[2002:a0a4:22c]:55400,[2002:a0a4:22c]:2525,<,250 XProxyFrom accepted,
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,305,[2002:a0a4:22c]:55400,[2002:a0a4:22c]:2525,*,,sending message with RecordId 31121 and InternetMessageId <BTqQZEU-GNTa3-AAAAAAAAAACcAQAATTPRJKGi-federico@domain.gov.ar>
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,306,[2002:a0a4:22c:]:55400,[2002:a0a4:22c]:2525,>,MAIL FROM:<federico@domain.gov.ar> SIZE=0 AUTH=<> XMESSAGEVALUE=MediumHigh,
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,307,[2002:a0a4:22c:]:55400,[2002:a0a4:22c]:2525,>,RCPT TO:<tickets.administrador@domain.gov.ar>,
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,308,[2002:a0a4:22c]:55400,[2002:a0a4:22c]:2525,<,250 2.1.0 Sender OK,
2019-11-29T16:27:42.677Z,Conector de proxy de entrada y envĂo interno,08D76908C6D35678,309,[2002:a0a4:22c]:55400,[2002:a0a4:22c]:2525,<,250 2.1.5 Recipient OK,
