Yes that would work. Alternatively you could just export the data base on the old server and restore it on the new server, and then upgrade it on the new server.
[resolved] osTicket migration
Hi ntozier,
Thank you. I tried what you described above; however, when I try to run the upgrade on the new server the attached error message comes up.
I guess that you would have to look at the various upgrade scripts (for the db: at \include\upgrader\streams\core) and see if there are any that you need to run. That error says that it tried to create a column and that it already exists.
Since i am not really sure which scripts to run, I will upgrade my current system to the latest version first then export the dbs to the new system.
Thank you very much!
I'm getting exact same error. I've tried everything i can think of to upgrade. Stuck on 1.9.16.
Tried going through the upgrade scripts. The schema signature shows.'b26f29a6bb5dbb3510b057632182d138'
I'm stuck.
Hi ntozier,
I tried upgrading my current 1.9.16 to 1.14.1; however, when I tried to load the page, nothing loads. I am assuming the version of PHP that is running on my CentOS6 (5.3.3) is not compatible with OSticket 1.14.1.
I also tried installing a clean version of 1.9.16 to CentOS 8 and when I open up the browser, the setup page does not load. I am assuming 1.9.16 is not compatible with PHP version 7.2.11.
My question is which version can I upgrade my 1.9.16 install to that is compatible with PHP 5.3.3?
Please advise
Thank you
@ceantuco
I'm surprised that 1.9.16 works with PHP 5.3.x. PHP 5.3 reached end of life over 5 years ago.
https://www.php.net/eol.php
1.8 required PHP 5.3+
I thought that 1.9 required 5.6+
You can still use PHP 5.6 with 1.10, 1.11, 1.12, and 1.14.
ceantuco My question is which version can I upgrade my 1.9.16 install to that is compatible with PHP 5.3.3?
I do not believe that there is any version of osTicket that you can upgrade to with PHP 5.3.
ntozier
Yes, 1.9.16 has been working fine since I upgraded back in 2017. I created a CentOS 7 server and installed PHP 5.6.40 on it. I will attempt to install 1.9.16 then restore my current database and attempt to upgrade to the latest version 1.14.
Since CentOS tend to run older software, do you recommend using Debian or Ubuntu instead?
Please advise
Thank you!
You should be able to install newer versions of PHP on CentOS just fine.
Here are some articles that talk about it:
https://www.google.com/search?q=centos+install+php+7
ntozier Thank you.
I installed OSTicket version 1.9.16 successfully on CentOS 7 with PHP5.6. Also, I restored my current helpdesk database on the new server without issues except when I try to enable email fetching I get 'imap authentication cancelled'
Please note the same settings work okay on my old server. Can you help me or point me to the right direction?
php-imap is installed and enabled. Also, I added extension=imap.so to php.ini
Thank you
Could be incorrect IMAP login details/server details, double-check it
If you are using API Key then you would need to add new server IP and which will give you a new key
see link here:
it's located under:
Mange>API Keys>
https://github.com/osTicket/osTicket/blob/develop/setup/doc/api.md
Thank you for your help! I was able to upgrade to version 1.14.1 without issues!
You can close this ticket.
