ntozier
I did all what you recommend, but I get various errors after clicking upgrade, all concerning ost_translation:
here is the order they were emitted:
DB Error #1146
[SELECT A1.* FROM ost_translation A1 WHERE A1.type = 'article' AND A1.object_hash = 'cc78cd3b9390da92'] Table 'ost.ost_translation' doesn't exist
SELECT A1.* FROM ost_translation A1 WHERE A1.lang = 'en_US' AND A1.type = 'phrase'] Table 'ost.ost_translation' doesn't exist
then a stacktrace follows. I can post that if you think it'll help. I was careful to use the same collation (utf-8) on export as import.
Is there anything I can do on the old or new server to fix?
thanks,
