[deleted]
As mentioned, not sure you can. I would contact the devs directly. Use the Contact Us link at the top of the page
osTicket 1.5 is not downloadable and hasn't been for many years. I do have a copy of 1.6ST, and 1.7+ is still downloadable if you know where to look.
From memory (which may be faulty):
It sounds to me like if you are running PHP 5.6+ you are fine to run the contemporary version.
1.6ST
https://tmib.net/files/OST_1.6.zip
1.7.0
https://tmib.net/files/osTicket-1.7.0.zip
Additionally, you can download all 29 of the 1.7 releases at github:
https://github.com/osTicket/osTicket-1.7/releases
Generally you would follow the installation instructions.
This is for the current version but it shouldn't be much different.
https://docs.osticket.com/en/latest/Getting%20Started/Installation.html
You need to:
As a side note technology has changed a lot in the past decade so you may experience problems with things like collecting emails, sending emails, etc. These versions are ancient.
1.6 is no longer supported and hasn't been for years and years so I have no idea. I also do not run that version.
That button has been there as long as I can remember though.
The reason why I posted on the other discussion its because the Title can make it noticeable to other users. As this discussion was for other reason and not the Attachment, so Im asking please if you can open the other Thread that you have just closed, and this one you can close it instead, CAN YOU?
Sure I'll close this one instead.
