I think you can start with \include\staff\templates\queue-tickets.tmpl.php
priority button
PavelH thanks, but in \queue-tickets.tmpl.php, i can't find the code of this buttons.. http://prntscr.com/ngpf6j
Attached picture say more.
But as I say, this file is only start.
No, genius is Kevin and Neil. I just want to help with my experience because I know how difficult it is to be alone for all these things.
What do you need is:
1. Place a button and set him as hyperlink. You can use others buttons as an example.
2. Find and fill targeting file with your code for priority change.
PavelH I think is the 2. I need to cllick button and appear this box http://prntscr.com/nh6dve
Yes. This is one of many options.
There is no code at this time. You have to write it yourself.
I still need help with this function, if anyone knows?
According to your first question "what file do I have to edit", I thought you were a programmer.
But as I can see, you need someone to write your code. You can ask here: http://software-mods/index.html.
If you are the first person to send an idea and they make your idea into a plugin, you receive a free copy of the plugin.
