awstech I'm in the exact same situation here: Shibboleth SSO here with restrictions on local credentials.
This leads me to suspect that there is an issue not with osTicket, but with cPanel (considering we both have the same issue, and non cPanel users are not reporting the issue). Unclear what exactly the issue there might be though....
@awstech and @rgonig2
When you get the error "(defunct — missing)", if you click on that what you see?
normally it means you don't have correct permission or that plugin is not incorrect path: /include/plugins
rgonig2
Are you able to delete it from GUI and delete directory in plugin too and re-add it
Attempting to delete via GUI causes 500 server error.
Deleting plugin in directory has no effect, deleting relevant rows in ost_plugins and ost_config table removes plugin.
    rgonig2
    I noticed earlier post when KevinTheJedi asked to run command it said permission denied
    That means you need to run the command as sudo like
    $ sudo chmod -R 0644 include/plugins/
    $ sudo chown -R www-data:www-data include/plugins
    You need to make sure you are in current location or use full path
    Restart Apache and retest
      ramrajone Please read the rest of the thread. I am an end user at my institution, and the server I am hosting on is provided via cPanel. As previously mentioned, I am not able to reset Apache, as this service is maintained at the institution level cPanel and institution admins. The path was not an issue.
      As for the perms issue in the first place, the auth-ldap.phar file has a numerical value of 0644 and is owned by the service user.
        We apologize for the inconvenience caused to you.
        However @rgonig2 has opened a ticket with us highlighting this issue to us.
        We made a test installation of the old version i.e v1.10.4 and had LDAP plugin installed and then upgraded the installation to v1.11 via Softaculous itself and the plugin post upgrade was listed properly.
        We request all users on this thread, if they have any issues with the installation/upgrade made via Softaculous to open a ticket with us so that we can check this for you.
        https://www.softaculous.com/support/
        We request for ticket because we may need some more details like the installation details OR the control panel login in order to check this further for you.
        Also we follow the standard upgrade procedure which is given by the OSTicket itself.
        Thank you.
          rgonig2
          Well, based on all things you tried, it seems the issue is permission related as suggested report bug to them softaculous and your issue should be fixed
          This is what I was pointing out in my last response, even though you had run the command, but show Permission denied:
          ntozier Probably as resolved as it's gonna get, since it appears not to be an issue with osTicket, but some aspect of cPanel/Softaculous
          ntozier If you'd like, unless you can think of any devs who might be able to provide insight into how osTicket loads plugins, and in particular what services are used to do so? I ask because my institution added me to their cPanel dev environment, and there are no issues there, which leads me to believe there must be some difference between the two environments in what osTicket needs to load and run plugins, the trick is just figuring out what...
          I have an idea.
          Can you:
          remove the plugin.
          unphar the plugin and put that directory in your /plugins folder?
          Just to confirm:
          Remove auth-ldap.phar from include/plugins
          Unpack auth-ldap.phar
          Place unpacked filed back into include/plugins
          Nothing with tables.
            @rgonig2
            All you need for plugins is the php-phar extension installed and enabled. This will do all the work of unpacking the phar and loading it.
            @KevinTheJedi Phar is bundled with PHP as pf version 5.3 and enabled by default. So there shouldn't be anything that needs to be installed. But it does need to be enabled. (ie it has to be turned off on purpose to not work... there is a command line --disable-phar that is used to shut it off.
              ntozier Following these steps
              rgonig2 Remove auth-ldap.phar from include/plugins
              yielded no positive results, though I was unsure what to name the directory when I placed it back in /plugins.
              the same name as the plugin phar had. So auth-ldap.phar would become a folder named auth-ldap.
              The contents of the auth-ldap folder would look like this:
                ntozier Okay, got the folder name right "auth-ldap", but I definitely did not get the same extraction:
                What tool are you using?
