ntozier
So just export the database and import, then login and done?
Can I do this after the installation of osTicket, or do I do this before installing osTicket?
Is there a step-by-step I can read?
Upgrade from v.1.10.4 to v.1.11.0-rc1
1. Make sure you have a backup of Database and files of osTicket
2. Then put the system in the offline mode
3. Upload v. 1.11.0-rc1 and replace current files/folders from Upload folder of your downloaded, and exclude the script folder/files
4. Copy ost-config.php from current /include folder to osTicket server same location /include, then restore the .sql backup if it's a different server
5. Make sure you have the correct permission, then go to the URL of the osTicket system and login
6. Delete the /setup folder and update any customization you may have
That’s it, note because this upgrade did have database changes so you will see the upgrader screen. Version 1.10.1 to 1.10.4 did NOT have any database change so you will not see upgrade screen
If you want you can run manually upgrader: /scp/upgrade.php
    ramrajone
    I already have a new server setup with a fresh clean vanilla copy of osTicket v1.11.0-rc1 installed.
    Can I skip step #3 and just import the old database into it?
    Or do I need to wipe it, install osTicket 1.10.4 and then follow the steps above?
    ntozier
    Thanks guys, I attempted the upgrade, it told me "Something went wrong" then it took me to the 'upgrade complete'.
    I tried going to the Admin panel, and got the same HTTP ERROR 500.
    I looked in the logs, and I'm still running into that same error I posted above:
    [Wed Jan 23 12:39:24.240392 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP Fatal error:  Class name must be a valid object or a string in /var/www/html/osticket/upload/include/class.forms.php on line 1088
    [Wed Jan 23 12:39:24.240428 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP Stack trace:
    [Wed Jan 23 12:39:24.240437 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   1. {main}() /var/www/html/osticket/upload/scp/index.php:0
    [Wed Jan 23 12:39:24.240444 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   2. require() /var/www/html/osticket/upload/scp/index.php:17
    [Wed Jan 23 12:39:24.240451 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   3. CustomQueue->getQuery() /var/www/html/osticket/upload/scp/tickets.php:531
    [Wed Jan 23 12:39:24.240458 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   4. CustomQueue->getBasicQuery() /var/www/html/osticket/upload/include/class.queue.php:832
    [Wed Jan 23 12:39:24.240465 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   5. CustomQueue->mangleQuerySet() /var/www/html/osticket/upload/include/class.queue.php:819
    [Wed Jan 23 12:39:24.240473 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   6. CustomQueue->getSupportedMatches() /var/www/html/osticket/upload/include/class.queue.php:884
    [Wed Jan 23 12:39:24.240480 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   7. CustomQueue::getSearchableFields() /var/www/html/osticket/upload/include/class.queue.php:309
    [Wed Jan 23 12:39:24.240487 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   8. DynamicFormField->getImpl() /var/www/html/osticket/upload/include/class.queue.php:362
    [Wed Jan 23 12:39:24.240494 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP   9. DynamicFormField->__call() /var/www/html/osticket/upload/include/class.queue.php:362
    [Wed Jan 23 12:39:24.240501 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP  10. call_user_func_array:{/var/www/html/osticket/upload/include/class.dynamic_forms.php:600}() /var/www/html/osticket/upload/include/class.dynamic_forms.php:600
    [Wed Jan 23 12:39:24.240509 2019] [:error] [pid 11896] [client 10.2.10.102:55220] PHP  11. FormField->getImpl() /var/www/html/osticket/upload/include/class.dynamic_forms.php:600
      Pietro_Aretino
      Take a look at this link about your error: PHP Fatal error: Class name must be a valid object or a string in
      https://forum.osticket.com/d/89888-resolved-problems-with-upgrade-from-1912-to-110/2
      it seems like PHP or something you have in the custom form that does not like, which version are you running? Can you try 7.0.x?
        ramrajone
        Come to think of it, I did do some customization in the Form tables in the database.
        Damn. I wonder if there's a way if I can import everything but exclude the ost_form tables...
        Thanks ramrajone.
          Pietro_Aretino
          sorry, I am not good at making changes to the database, someone else might help you out, good luck
          So I built a quick shell script that allows me to rebuild the entire database structure, and ignore the data in the tables of the database that I customized. That way the customized tables will not be imported, just their structure; just because the initial errors I was getting were related to the "lists" and "form" related tables in the database, as those were the ones I had customized.
          #!/bin/bash
          PASSWORD="password"
          HOST=localhost
          USER=osticket
          DATABASE=osticket
          DB_FILE=dump.sql
          EXCLUDED_TABLES=(
          ost_form
          ost_form_entry
          ost_form_entry_values
          ost_form_field
          ost_help_topic_form
          ost_list
          ost_list_items
          IGNORED_TABLES_STRING=''
          for TABLE in "${EXCLUDED_TABLES[@]}"
          do :
             IGNORED_TABLES_STRING+=" --ignore-table=${DATABASE}.${TABLE}"
          done
          echo "Dump structure"
          mysqldump --host=${HOST} --user=${USER} --password=${PASSWORD} --single-transaction --no-data --routines ${DATABASE} > ${DB_FILE}
          echo "Dump content"
          mysqldump --host=${HOST} --user=${USER} --password=${PASSWORD} ${DATABASE} --no-create-info --skip-triggers ${IGNORED_TABLES_STRING} >> ${DB_FILE}
          So I did that, exported the database, then uploaded it and now I got different errors:
          PHP Fatal error:  Uncaught exception 'DoesNotExist' in /var/www/html/osticket/upload/include/class.orm.php:1343\nStack trace:\n
          #0 /var/www/html/osticket/upload/include/class.dynamic_forms.php(483): QuerySet->one()\n
          #1 /var/www/html/osticket/upload/include/class.dynamic_forms.php(478): TicketForm::getNewInstance()\n
          #2 /var/www/html/osticket/upload/include/class.ticket.php(2190): TicketForm::getInstance()\n
          #3 /var/www/html/osticket/upload/include/class.queue.php(343): Ticket::getSearchableFields()\n
          #4 /var/www/html/osticket/upload/include/class.queue.php(309): CustomQueue::getSearchableFields('Ticket')\n
          #5 /var/www/html/osticket/upload/include/class.queue.php(884): CustomQueue->getSupportedMatches()\n
          #6 /var/www/html/osticket/upload/include/class.queue.php(819): CustomQueue->mangleQuerySet(Object(QuerySet))\n
          #7 /var/www/html/osticket/upload/include/class.queue.php(832): CustomQueue->getBasicQuery(false)\n
          #8 /var/www/html/osticket/upload/scp/tickets.php(531): CustomQueue->getQuery(false, NULL)\n
          #9 /var/www/html/osticket/upload/scp/index.php in /var/www/html/osticket/upload/include/class.orm.php on line 1343, referer: http://ops.nhsocal.com/scp/upgrade.php?c=4&r=21
          Any ideas? What 'DoesNotExist'?
          17 days later
          Strange. Well at the moment I'm trying to dump everything except the "Form" related tables and use the vanilla structure of those tables. I'll see if that works.
