@[deleted]Amazing, working perfectly. One of last question (probably lol). Is there a way to make tickets that were deleted in the helpdesk system to not show in the query? I just noticed there are a couple in there that someone had deleted but are still pulling in the query. Just curious. Going forward i'll make sure tickets are not deleted so it shouldn't be a problem but if there is a way in the query to not show those, that would be great. Thanks a ton again.
Hello @[deleted], how did you delete the ticket? Because if you delete it using the facility, it removes the entry from the database table. You might want to add this then, but it is a wild shot really:SELECT ost_ticket.number AS "Ticket Number", ost_ticket__cdata.subject AS "Subject", ost_user.name AS "Created By", CONCAT(ost_staff.firstname," ", ost_staff.lastname) AS "Agents Name", SUM(ost_thread_entry.time_spent) AS "Time Spent", CONCAT("https://your.osticket.com/scp/tickets.php?id=",ost_ticket.ticket_id) AS "Link" FROM ost_ticket LEFT JOIN ost_staff ON ost_ticket.staff_id=ost_staff.staff_id, ost_thread_entry, ost_thread, ost_ticket__cdata, ost_user WHERE  ost_ticket.ticket_id=ost_thread.object_id AND ost_thread.id=ost_thread_entry.thread_id AND ost_ticket.ticket_id=ost_ticket__cdata.ticket_id AND ost_ticket.user_id=ost_user.id AND ost_ticket.created>='2017-01-01' AND ost_ticket.created<='2017-02-01' AND ost_user.name='Full Name' AND ost_ticket.status_id IN ('1','2') GROUP BY ost_ticket.ticket_id;Remove or add the extra number depending what you need:+----+----------------------+----------+| id | name                 | state    |+----+----------------------+----------+|  1 | Open                 | open     ||  2 | Resolved             | closed   ||  3 | Closed               | closed   ||  4 | Archived             | archived ||  5 | Deleted              | deleted  ||  6 | Faulty Unit returned | open     ||  7 | AR sent              | open     ||  8 | Monitoring           | open     ||  9 | Feature Request      | open     |+----+----------------------+----------+
@[deleted]It would be when you go into the ticket, click the gear icon and then hit delete ticket. I can see where the difference is. I was using the out of the box ticket number system and then changed it to 1, 2, 3, etc. Seems there is just a minor difference between that ticket number and the id. Not a problem at all and it is working as you had mentioned it should be.
a year later
@[deleted]I wanted to thank you for your help here as this was almost exactly what I was looking for. I was able to make some minor modifications to the query for my needs but I can't seem to figure out how to pull the organization name in as well. The whole join thing makes my head hurt. Any thoughts on how to get that info as well? And I guess while I'm asking do you know how to generate a link using the auth token so users without a login can view the tickets?
Hello @[deleted], you would need to add:SELECT ost_ticket.number AS "Ticket Number", ost_ticket__cdata.subject AS "Subject", ost_user.name AS "Created By", CONCAT(ost_staff.firstname," ", ost_staff.lastname) AS "Agents Name", SUM(ost_thread_entry.time_spent) AS "Time Spent", CONCAT("https://your.osticket.com/scp/tickets.php?id=",ost_ticket.ticket_id) AS "Link", ost_organization.name AS "Organisation" FROM ost_ticket LEFT JOIN ost_staff ON ost_ticket.staff_id=ost_staff.staff_id, ost_thread_entry, ost_thread, ost_ticket__cdata, ost_user LEFT JOIN ost_organization ON ost_user.org_id=ost_organization.id WHERE  ost_ticket.ticket_id=ost_thread.object_id AND ost_thread.id=ost_thread_entry.thread_id AND ost_ticket.ticket_id=ost_ticket__cdata.ticket_id AND ost_ticket.user_id=ost_user.id AND ost_ticket.created>='2017-01-01' AND ost_ticket.created<='2017-02-01' AND ost_user.name='Full Name' GROUP BY ost_ticket.ticket_id;Organisation table must be linked from ost_user.org_id, it links directly into ost_organization.id :) As for auth tokens, I am not sure, but I believe there was an addon(clickedy) that allowed public to view currently open tickets. That was for 1.7 version of osTicket, you would need to look for an updated version of it (if there is one).
a month later
Hello,@[deleted]I have modified this as below;SELECT ost_ticket.number AS "Ticket Number", ost_ticket__cdata.subject AS "Subject",ost_ticket.Source AS "Source",ost_user.name AS "Created By",ost_ticket.created AS "Ticket Opened", CONCAT(HOUR(TIMEDIFF(ost_ticket.created, ost_ticket.lastupdate)), ' Hours ', MINUTE(TIMEDIFF(ost_ticket.created, ost_ticket.lastupdate)), ' Minutes') AS "Created to Last Update time",  CONCAT(ost_staff.firstname," ", ost_staff.lastname) AS "Agents Name", CONCAT("http://ostticket//scp/tickets.php?id=",ost_ticket.ticket_id) AS "Link" FROM ost_ticket LEFT JOIN ost_staff ON ost_ticket.staff_id=ost_staff.staff_id, ost_thread_entry, ost_user, ost_thread, ost_ticket__cdata WHERE ost_ticket.ticket_id=ost_thread.object_id AND ost_thread.id=ost_thread_entry.thread_id AND ost_ticket.ticket_id=ost_ticket__cdata.ticket_id AND ost_ticket.user_id=ost_user.id AND ost_ticket.created>='2018-05-07' AND ost_ticket.created<='2018-06-07' GROUP BY ost_ticket.ticket_id;Is there a way to find the time between a state change? As some get put on hold but would still mean we're within the SLA etc. Some have it where user emails, we reply and place on hold, they never respond and we close 2 days later. This leads to about 53 hours "created to last update".Regards(If someone else wants this SQL, it basically provides number, subject, source, created by user, opened time, created to last update, agent name and link.
Ok, I think this should give a good view of when the ticket was replied too. This might help some people for better reports outside of the time spentSELECT ost_ticket.number AS "Ticket Number", ost_ticket__cdata.subject AS "Subject",ost_ticket.Source AS "Source",ost_user.name AS "Created By",ost_ticket.created AS "Created",ost_ticket.closed AS "Closed",CONCAT(HOUR(TIMEDIFF(ost_ticket.created, ost_thread_entry.created)),' Hours ',MINUTE(TIMEDIFF(ost_ticket.created,  ost_thread_entry.created)), ' Minutes') AS "Reponse time",CONCAT(ost_staff.firstname," ", ost_staff.lastname) AS "Agents Name",CONCAT("http://ost/scp/tickets.php?id=",ost_ticket.ticket_id) AS "Link"FROM ost_ticket LEFT JOIN ost_staff ON ost_ticket.staff_id=ost_staff.staff_id, ost_thread_entry, ost_user, ost_thread, ost_ticket__cdata WHERE ost_ticket.ticket_id=ost_thread.object_id AND ost_thread.id=ost_thread_entry.thread_id AND ost_ticket.ticket_id=ost_ticket__cdata.ticket_id AND ost_thread_entry.type like 'R' AND ost_ticket.user_id=ost_user.id AND ost_ticket.created>='2018-05-07' AND ost_ticket.created<='2018-06-07' GROUP BY ost_ticket.ticket_id;
Only issue with using `R` it will only show if they got a reponse, if they got closed on creation it will not
5 years later
Hi
How can I build a query on the number of open and closed cards during a month, day, or the like???
