Hi, wondered if anyone could help. Is there a way to remove theneed for help topic. The way we'd be using the system it wouldn't need users to keep selecting the topic, so would be a great help if i could just disable it. We're currently using the latest RCPete
Q: Is there a way to remove theneed for help topic.A: There is no way to do so at this time using the UI.
As far as I know the only way is to modify the source code.To do so, take a look at this topic: http://forum.osticket.com/d/discussion//mod-support-as-the-default-help-topic
Thank you @[deleted] and Thanks for that thead @[deleted] Pete
