"One more question is that possible to add html editor like this forum
for the customer view. Currently customer can not select any color
changed for text."There actually is an HTML editor, it's built into osTicket and called Redactor. I don't think that he could or would want to change that.  But it is possible.
@[deleted]: This is a problem of the dynamic form generator. Here's the quick solution:1. Login into the backend2. Goto "Admin Panel" > "Manage" > "Forms"3. Choose "Ticket Details"4. Choose the field you like to edit5. Click on "Config"6. Change the size to a value, that matches your needs.To change it for the future some not theme related core files must be edited. Maybe I will do this after finishing responsive backend theme. ;o)Best regards,Jürgen
@[deleted] got the email thanks.
@[deleted]: You are welcome! If you like to see, what we are doing on theme work for osticket 1.10. RC2 have a look here: http://demo.osticket.direktmarketingtool.de/1.10.001/index.phpHave you seen the dynamic slider for featured FAQs?
@[deleted] Existing Redactor not giving this option to select text colour for in the client view.@[deleted]Is that change remain responsive. Thanks
  UPDATE: All input fields, even created in the dynamic form generator, are now responsive.   Please replace "include" > "client" > "footer.inc.php" with the attached one. Here you can download the actual version:http://cloud.direktmarketingtool.de/index.php/s/CP1r2O0zVX8RArT/downloadPassword: DMTEXTBASICRC3Best regards,Jürgen@[deleted]: Hope this will solve your problems. Thanks for your feedback!
Looking great! Hope we get a stable release soon.Regards,Marvin M
The stable version is out, all RC versions are removed from our cloud server. Please follow this thread:http://forum.osticket.com/d/discussion//dmt-free-responsive-theme-extended-basic-great-pumpkin-stable-1-0-for-osticket-1-9-12
@[deleted]: Please close this discussion.
4 months later
looking forward to try this theme out.
6 years later
DMTGMBH I am failing to download RC3 from your cloud server, kindly assist with the username and password is: DMTEXTBASICRC3 correct me if I am wrong
You will have to reach out to the author for support.
Although back in 2015 they said "all RC versions are removed from our cloud server"
