With ODATA becoming more and more popular and quite frankly amazing with Microsoft's Power BI tool, is there a way to setup OSTicket to allow for ODATA  Connections?
Is it something expected in future releases?
Do you know if some of the 3rd party products can tie into the PHP/MySQL configuration to create the ODATA Connection?
Maybe using DreamFactory and REST ?
Q: Is it something expected in future releases?A: I'm not aware of any discussion regarding this, but I also live about 1200 miles away from the devs, so.. Q: Do you know if some of the 3rd party products can tie into the PHP/MySQL configuration to create the ODATA Connection?A: It's PHP... any application that can read the config file could pull data from the database.  You would just have to write the queries.Q: Maybe using DreamFactory and REST ?A: I have never heard of "DreamFactory".  There are plans to rework the API and my understanding is that its intended to be a full (RESTful) API.  What that will look like in reality I have no idea as work on rewriting the API hasn't started to my knowledge.
