osTicket 1.9.3, ISS 7.5, PHP 5.5.16, MySQL 5.0.46
Just installed osTicket 1.9.3, my admin page loads correctly with pictures and formatted text, but client side has no pictures or any CSS formatting-just plain txt what am I missing?
upgrade or new install?If upgrade clear your browser cache.If new install, please consult your IIS error log for the site and see what if any errors are reported.
New install
I'm looking through the logs not seeing anything...what should I be looking for?
Your webserver telling you that the css file isn't found (404).
Here's the log...I removed the IP's and server name for this post.xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 1232, 308, 4336, 200, 0, GET, /support/, -,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 338, 1405, 404, 2, GET, /css/osticket.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 350, 1405, 404, 2, GET, /assets/default/css/theme.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 350, 1405, 404, 2, GET, /assets/default/css/print.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 335, 1405, 404, 2, GET, /scp/css/typeahead.css, -,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 362, 1405, 404, 2, GET, /css/ui-lightness/jquery-ui-1.10.3.custom.min.css, -,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 336, 1405, 404, 2, GET, /css/thread.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 338, 1405, 404, 2, GET, /css/redactor.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 346, 1405, 404, 2, GET, /css/font-awesome.min.css, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 375, 1405, 404, 2, GET, /js/jquery-ui-1.10.3.custom.min.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 364, 1405, 404, 2, GET, /js/jquery-1.8.3.min.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 364, 1405, 404, 2, GET, /js/jquery.multifile.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 356, 1405, 404, 2, GET, /js/osticket.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 371, 1405, 404, 2, GET, /scp/js/bootstrap-typeahead.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 360, 1405, 404, 2, GET, /js/redactor.min.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 365, 1405, 404, 2, GET, /js/redactor-osticket.js, bba9ccc,xxx.xxx.xxx.xxx, -, 10/9/2014, 13, W3SVC3, server-name, xxx.xxx.xxx.xxx, 0, 359, 1405, 404, 2, GET, /logo.php, -,
And do those css files exist?
They do exist...the folder I dropped everything into is support ( so domain.com/support ) looking at the log at the second hit down its looking for /css/osticket.css, bba9ccc is it missing "support/"? Just a thought, or does the weird "bba9ccc" have something to do with it? I'm at loss at why this is happening.
Whats your Helpdesk URL at: Admin panel -> Settings?
see attached
It looks like ROOT_PATH is not being setup correctly. Could you share some information about your server configuration: what path is /support/ served from on the filesystem? Do you have a virtual directory or website configured?You can configure the ROOT_PATH in the config file by uncommenting the lines that define it and set the ROOT_PATH to /support/
Setup as website c:\inetpub\wwwroot\gps\ and then support is nextI'm not certain what config file your talking about sorry...still learning.
You're talking about the ost-config.php I'm a bit slow sorry about that.Yes I have checked that and it was un-commented already with /support/ Just to see if i could break it, I changed it to /support1234/ and it made NO difference. I still get this (see attached).
Not to mention, the three links up top dont work and are missing /support/ but the "open a new ticket" and "check ticket status" are working and have the /support/ in the link.
any suggestions??
I really could use some help on this.
I got it.It was the web.config file provided in the install. Once I copied over it with a default web.config file it works great.
I'm going to close this thread since you have found your own solution.I'm glad that you got things sorted, please feel free to start a new thread if you have another question.
