Hi,Currently using OSTICKET 1.7.0 and  I want to upgrade so that I can use the file storage plugin, and stop storing attachments in the database.My file_chunk table is currently 382Mb, so after the upgrade I'd like to change the attachments in the DB, to be stored as files. Is this possible ?Any advice on dealing with large file_chunk tables would be appreciated.RegardsJohn
5 days later
Once you have upgraded yes you can move the files out of the database and into the file system.You would need to install and configure the storage-fs plugin (and enable it). You can then migrate your attachments to a different backend via the command-line Get a list of configured storage backends$ php setup/cli/manage.php file backendsMigrate 100 attachments from database to filesystem:$ php setup/cli/manage.php file migrate --backend=D --to=F --limit=100Attachments of 8000 bytes and less do not affect database performance characteristics, so you could leave small attachments in the database if you wanted:$ php setup/cli/manage.php file migrate --backend=D --to=F --limit=100 --min-size=8000
Thanks for the advice.I've made the upgrade and applied the plugin.The storage-fs plugin appears to be working, as from OSticket I can get the attachment, and it is not in the file chunk file.However when I look at the folder for attachments all I can see is folders named A, M and N which have been created on receipt of an attachment. These folders seem to be empty, I was expecting to see the files I had put in the email.
I haven't switched back and forth personally so I'm not real sure what it should look like.  Did you run the migrate command? I dont think that it uses the filename for the files though.  I think that it generates unique ones.
