The part I am having trouble with is how to declare a variable in class.ticket.php and set this variable to getUser()->getOrganization(), then accessing this variable in my tickets.inc.php to display it in my table
$qselect ='SELECT ticket.ticket_id,tlock.lock_id,ticket.`number`,ticket.dept_id,ticket.staff_id,ticket.team_id'      .' ,user.name'      .' ,email.address as email, dept.dept_name'      .' ,ticket.status,ticket.source,ticket.isoverdue,ticket.isanswered,ticket.created'      .' ,topic.topic'      .' ,organization.name';$qfrom=' FROM '.TICKET_TABLE.' ticket '.       ' LEFT JOIN '.USER_TABLE.' user ON user.id = ticket.user_id'.       ' LEFT JOIN '.USER_EMAIL_TABLE.' email ON user.id = email.user_id'.       ' LEFT JOIN '.DEPT_TABLE.' dept ON ticket.dept_id=dept.dept_id '.       ' LEFT JOIN '.TOPIC_TABLE.' topic ON ticket.topic_id=topic.topic.id'.       ' LEFT JOIN '.ORGANIZATION_TABLE.' organization ON user.org_id = org.org_name';I feel like I am setting this up to get the organization name correctly but something isn't right with my select and my from statements any ideas?
try replacing: ' LEFT JOIN '.ORGANIZATION_TABLE.' organization ON user.org_id = org.org_name'with ' LEFT JOIN '.ORGANIZATION_TABLE.' organization ON user.org_id = org.id'
Thank you very much.  Another thing I changed was 'organization.name as org_name' in the select statement because just having 'name' conflicted with 'user.name' if that makes sense.  I wasn't able to get a handle to my organization name.  I will comment the changes that I made to this file to get it to work soon so that others who are looking to do the same thing will be able to do so more easily.  I appreciate the help!
I was wondering is there any way to access the organization field that is a part of the newly created ticket.  Such as the organization that the ticket was created for and not necessarily the organization of the user who created it?  I think this is more where I wanted to go with this but I am not sure where this organization data is located within the database.
I know it is part of a form I'm just not sure if there is an easy way to accomplish this.
Would be awesome to have the organization that the ticket was created for as a value in the ost_ticket database for future releases.  I don't understand why this is part of a dynamically added form.
SOLUTION:Figured out that you can access the organization that the ticket was created for by adding the following highlighted line around line 235(approx.)://ADD attachment,priorities, lock and other crap$qselect.=' ,IF(ticket.duedate IS NULL,IF(sla.id IS NULL, NULL, DATE_ADD(ticket.created, INTERVAL                sla.grace_period HOUR)), ticket.duedate) as duedate '         .' ,CAST(GREATEST(IFNULL(ticket.lastmessage, 0), IFNULL(ticket.closed, 0),                   IFNULL(ticket.reopened,  0), ticket.created) as datetime) as effective_date '         .' ,CONCAT_WS(" ", staff.firstname, staff.lastname) as staff, team.name as team '         .' ,IF(staff.staff_id IS NULL,team.name,CONCAT_WS(" ", staff.lastname, staff.firstname)) as assigned '         .' ,IF(ptopic.topic_pid IS NULL, topic.topic, CONCAT_WS(" / ", ptopic.topic, topic.topic)) as helptopic '         .' ,cdata.priority_id, cdata.subject, cdata.organization as ticket_org, pri.priority_desc, pri.priority_color';$qfrom.=' LEFT JOIN '.TICKET_LOCK_TABLE.' tlock ON (ticket.ticket_id=tlock.ticket_id AND tlock.expire>NOW()               AND tlock.staff_id!='.db_input($thisstaff->getId()).') '       .' LEFT JOIN '.STAFF_TABLE.' staff ON (ticket.staff_id=staff.staff_id) '       .' LEFT JOIN '.TEAM_TABLE.' team ON (ticket.team_id=team.team_id) '       .' LEFT JOIN '.SLA_TABLE.' sla ON (ticket.sla_id=sla.id AND sla.isactive=1) '       .' LEFT JOIN '.TOPIC_TABLE.' topic ON (ticket.topic_id=topic.topic_id) '       .' LEFT JOIN '.TOPIC_TABLE.' ptopic ON (ptopic.topic_id=topic.topic_pid) '       .' LEFT JOIN '.TABLE_PREFIX.'ticket__cdata cdata ON (cdata.ticket_id = ticket.ticket_id) '       .' LEFT JOIN '.PRIORITY_TABLE.' pri ON (pri.priority_id = cdata.priority_id)';Put ticket_org in your TD and there you go!
FULL SOLUTION TO ADD ORGANIZATION COLUMN TO MAIN STAFF TICKET VIEW:Line 151 (estimate):  Make sure your sort array looks like this:$sortOptions=array('date'=>'effective_date','ID'=>'ticket.`number`',    'pri'=>'pri.priority_urgency','name'=>'user.name','subj'=>'cdata.subject',    'status'=>'ticket.status','assignee'=>'assigned','staff'=>'staff',    'dept'=>'dept.dept_name', 'helptopic'=>'helptopic', 'organization'=>'ticket_org');Disregard the helptopic portion because I also added a help topic column to my staff ticket view.  Add the part highlighted in green.  NOTE:  ticket_org would be org_name depending on what organization you wish to include in the ticket view.  You will see what I mean in the following: Line 204 (estimate):  If you want to add the organization of the user who created the ticket, modify the following qselect and qfrom statements by adding the highlighted portion:$qselect ='SELECT ticket.ticket_id,tlock.lock_id,ticket.`number`,ticket.dept_id,ticket.staff_id,ticket.team_id '      .' ,user.name, user.org_id'      .' ,email.address as email, dept.dept_name '      .' ,ticket.status,ticket.source,ticket.isoverdue,ticket.isanswered,ticket.created'      .' ,organization.name as org_name';$qfrom=' FROM '.TICKET_TABLE.' ticket '.       ' LEFT JOIN '.USER_TABLE.' user ON user.id = ticket.user_id'.       ' LEFT JOIN '.USER_EMAIL_TABLE.' email ON user.id = email.user_id'.       ' LEFT JOIN '.DEPT_TABLE.' dept ON ticket.dept_id=dept.dept_id '.       ' LEFT JOIN '.ORGANIZATION_TABLE.' organization ON user.org_id = organization.id';If you want to add the organization that the ticket was created for, modify the following qselect and qfrom statements beginning around line 235 (estimate):NOTE: If you want Organization to be a part of the New Ticket form, you
must add it to the ticket.  If you are Admin you can add this custom
field to the new ticket screen
by going to Manage -> Forms.  When you are viewing the list of forms
you can click on Ticket Details, and then after Priority Level under the
Form Fields section you can add a new field, call it "Organizations",
and set the type to choices.  Click on config and it will let you enter a
list of choices that can be selected when the ticket is created in
order to specify what organization the ticket is for.  /ADD attachment,priorities, lock and other crap$qselect.=' ,IF(ticket.duedate IS NULL,IF(sla.id IS NULL, NULL, DATE_ADD(ticket.created, INTERVAL          sla.grace_period HOUR)), ticket.duedate) as duedate '         .' ,CAST(GREATEST(IFNULL(ticket.lastmessage, 0), IFNULL(ticket.closed, 0),                IFNULL(ticket.reopened,  0), ticket.created) as datetime) as effective_date '         .' ,CONCAT_WS(" ", staff.firstname, staff.lastname) as staff, team.name as team '         .' ,IF(staff.staff_id IS NULL,team.name,CONCAT_WS(" ", staff.lastname, staff.firstname)) as assigned '         .' ,IF(ptopic.topic_pid IS NULL, topic.topic, CONCAT_WS(" / ", ptopic.topic, topic.topic)) as helptopic '         .' ,cdata.priority_id, cdata.subject, cdata.organization as ticket_org, pri.priority_desc, pri.priority_color';$qfrom.=' LEFT JOIN '.TICKET_LOCK_TABLE.' tlock ON (ticket.ticket_id=tlock.ticket_id AND            tlock.expire>NOW()         AND tlock.staff_id!='.db_input($thisstaff->getId()).') '       .' LEFT JOIN '.STAFF_TABLE.' staff ON (ticket.staff_id=staff.staff_id) '       .' LEFT JOIN '.TEAM_TABLE.' team ON (ticket.team_id=team.team_id) '       .' LEFT JOIN '.SLA_TABLE.' sla ON (ticket.sla_id=sla.id AND sla.isactive=1) '       .' LEFT JOIN '.TOPIC_TABLE.' topic ON (ticket.topic_id=topic.topic_id) '       .' LEFT JOIN '.TOPIC_TABLE.' ptopic ON (ptopic.topic_id=topic.topic_pid) '       .' LEFT JOIN '.TABLE_PREFIX.'ticket__cdata cdata ON (cdata.ticket_id = ticket.ticket_id) '       .' LEFT JOIN '.PRIORITY_TABLE.' pri ON (pri.priority_id = cdata.priority_id)';All I did in the above qselect statement was get a handle to the organization name that is associated with that particular ticket by adding the highlighted statement.  The qfrom statement already has a handle to the table I want in the database so it is not necessary to modify it.Next, add your header to the table in the place that you want it.  I did mine right after Help Topic which I added right after Subject.  The headers start around line 325 (estimate):<th width="110"><a <?php echo $org_sort; ?> href="tickets.php?sort=organization&order=<?php echo $negorder; ?><?php echo $qstr; ?>" title="Sort By Organization <?php echo $negorder; ?>">Organization</a></th>Next you will want to add the TD which will be your table data.  Make sure this is placed in the same position as your header with
regards to the other columns so everything lines up.  This TDs start around line 420 (estimate):If you want to add the organization of the user who created the ticket:<td><?php echo (isset($row)) ? $row : '&nbsp';?></td>If you want to add the organization that the ticket was created for:<td><?php echo (isset($row)) ? $row : '&nbsp';?></td>Next, you will want to change the following line so that it corresponds to the number of columns in your table.  You can find this on line 470 (estimate): <td colspan="9">            <?php if($res && $num && $thisstaff->canManageTickets()){ ?>            Select:&nbsp;            <a id="selectAll" href="#ckb">All</a>&nbsp;&nbsp;            <a id="selectNone" href="#ckb">None</a>&nbsp;&nbsp;            <a id="selectToggle" href="#ckb">Toggle</a>&nbsp;&nbsp;This above change makes the footer span all columns.  I changed this to 9 because I have 9 columns in my Staff Ticket Overview.  This should be all that you need to successfully add the Organization to the Overview.  It is pretty much the same process for adding any column with whatever data you want.  Configure the sort array so you can sort based on the data in your column.  Get a handle to the table in your database that contains the values you want, add a header, add the data, and increase the footer to span all columns.  This is a somewhat complicated process and I've spent several days really getting to know the structure of the code so if I forgot something or left something out please feel free to message me or leave a comment and let me know.  I hope this helps other users out in the future and makes it easier to customize this ticket system. Enjoy!
I forgot to mention that the above changes all take place in the /staff directory in the file tickets.inc.php
4 months later
Is there any way to read some other fields of an organization other than the name. If possible what should I use instead of org.id. For example I would like to access the phone number stored under organization(not under User). I also have a custom form in which I have other fields also that I would like to access. Or is there anyway to look into the fields of ORGANIZATION_TABLE. It will be great if someone can help me on this.
2 months later
Great article. Used this with some minor modifications in 1.9.5.1.
7 months later
This works great. I'm using it with 1.9.12 and it seems to be ok.
8 months later
I did the same as you do but it didnt work :(I try :   <td><?php echo $ticket->getOwner()->getOrganization()  ;?></td>    and it work !But a great thanks for this tutoriel, it help me a lot
4 months later
Thanks so much for all your hard work motodave452. I've just applied your changes to v1.9.14 (8b927a0) and it works great.
Could you please post your changes, which you made and the filenames? I'm just working on the implementation of that mod in Version 1.9.14, too.Thank you very much in advance.
4 months later
Anybody trying add organization field to osticket v 1.10?
If you need this feature, use branch feature/custom-queueshttps://github.com/greezybacon/osTicket-1.8/tree/feature/custom-queues
17 days later
Hey, just wondering if anyone has done this on 1.10?Kiribool- I wasn't sure if your previous post was in relation to 1.10 or the current discussion/1.9?Thanks
