instale la version en español pero cuando creo un ticket no envia el numero del ticket al correo que ingreso, ya habilite todas las notificaciones y nada alguien puede ayudarme lo instale con wampserver
Puedes confirmar si recibes algun otro tipo de email enviado desde osTicket.Tambien puedes hacer algunas pruebas desde la parte de "Diagnostico". Mira el screen shot abajo.
A mi me pasa igual, he probado con Emails Diagnostic y tampoco me llega ningun Email
First of all there is no spanish version... so I'm not sure what you installed, but it was not distributed by us. Please install the version from osticket.com/downloads and see if it fixes your problem. If it does not then its likely that you have a problem with your email settings, or your php configuration.En primer lugar no hay una versión española ... así que no estoy seguro de lo que ha instalado, pero no fue distribuida por nosotros. Por favor, instale la versión de osticket.com / downloads y ver si se soluciona el problema. Si no es así, entonces es probable que usted tenga un problema con la configuración de correo electrónico, o la configuración de php.
I installed osTicket v1.9.2 yesterday
And did this fix your problem? Also please read and follow this thread: Please read before requesting assistance. Thank you.
No, I mean that I have that version and I have that problem, I don't have the Spanish VersionI still have this problem
You do realize that this isn't your thread... and that you likely have a very different issue from the one the person who opened this thread is having?Please don't hijack other peoples threads, and please start your own. You should include the information in Please read before requesting assistance. Thank you.
I didn't know, I'm so sorry.I will open my own thread.I'm new on this Forum..
