I have update the plugin file with the latest version and its still not working....here is a screenshot: http://screencast.com/t/Qh9l0FpxYrYJthanks...
Jared said grab a newer version of osTicket from github, not the plugin.
oh its kind of problem because it took me a whilte to upgrade to the 1.8.1 version (a lot a lot of customized code...) , is there is anyone here that knows what code has the bug fix and can refer me to the file ??thanks!
You would have to go through all the commits and closed issues to determine that.
where can i find the closed issues and commits ?thanks
On github. by clicking on issues.
thanks!
Welcome. :)
I didn't find anything in Osticket 1.8 issues and even in the plugin issues about this attachment problem...is there someone knows why its happening?
Hi to all, i have the exact same problem, some one know how to fix it?Thanks!
I have the same problem, basically the code of the plugin is on https://github.com/osTicket/core-plugins/blob/develop/storage-fs/storage.phpI'm trying to find the solution, since the hash folders are created but not the files.
@[deleted] so you're running osTicket 1.8.1?You should probably start your own thread and post your information.
