Hello,
I am testing osticket and looking at captcha. When I activate this feature and customer opens a new ticket from standard page, there is no problem.
However, if the customer is already logged in (with email and existing ticket id) and he decides to create a new ticket (using the icon) the captcha is not presented.
Hence the new ticket is not created.
If I remove captacha, the icon successfully creates a new ticket.
Am I missing some setting value to get captcha to work also for already logged-in customers ?
regards
I see this too with the captcha
Hi, I have seen this same issue if a user enters the captcha incorrectly on a new ticket, and the page refreshes to try again.. the captcha doesn't show up and the ticket entry fails, until you close your browser and open it again.
I have the captcha turned off for now
wms
a month later
up
same problem
Someone at a solution ?
well i got the same problem and found two solutions::
1. open /open.php and find
if(!$thisuser && $cfg->enableCaptcha()){
if(!$_POST)
$errors='Enter text shown on the image';
elseif(strcmp($_SESSION,md5($_POST)))
$errors='Invalid - try again!';
the problem is in !$thisuser first line in the above example line 23 in original code
replace that line with ::
if(!$thisuser && $cfg->enableCaptcha() && (!$thisclient || !$thisclient->isValid())){
so you will get something like this::
if(!$_POST)
this will allow clients to make a new ticket without captcha if you dont want this follow step 2
2. open /include/client/open.inc.php
and find::
<?if($cfg && $cfg->enableCaptcha() && (!$thisclient || !$thisclient->isValid())) {
as you can see this does the same as my fix in order to get the captcha working make the bug here
replace that line with::
<?if($cfg && $cfg->enableCaptcha()) {
this will show the capcha from now on
Regards,
Jamie Alexander Dekker
Developer, Programmer and System Analyst at
Rotterdam, The Netherlands
5 months later
Thanks
Thank you this works great!
3 months later
Hi!
I am suffering the same problem on a new install of v1.60 downloaded from the osTicket site yesterday. I applied the two corrections listed above by Alex1602 but this has not fixed the problem: The captcha is seen by the user the first time they create a ticket in a browser session but then not shown thereafter (so they cannot create a second ticket).
Any ideas on what needs to be done next? Was this thread relating to v1.60?
Any help appreciated by this newbie :-)
6 days later
Same problem here too. Going to try the posted fix and will report back.
Update
I used the second fix in the above code and it seems to work fine. Thank you!
2 months later
Not having as much luck
I have tried the second fix and it doesn't work still. Regarding the first fix, I couldn't find just open.php.
In open.php I'm not sure if:
Is a typo and should be
if(!$thisclient && $cfg->enableCaptcha()){
This would stop the Php checking for a captcha post from the add ticket form.
I echoed the errors I got when posting the form and its in this section that causes it.
I believe $thisclient refers to a client that is logged in. $thisuser ( I think ) is only set in the admin pages of osTicket.
I think the reason the captcha doesn't appear because its only needed to stop spam attacks when a user is not logged in.
If you want it to appear all the time then changing the following in open.php
//to
if( $cfg->enableCaptcha() ){
//Or
if( $cfg && $cfg->enableCaptcha() ){
And then changing the following in open.inc.php
if( $cfg && $cfg->enableCaptcha() && (!$thisclient || $thisclient->isValid() ){
//to
I'm not sure I'm following and with potential typos and going back and forth, I'm not sure what my code should look like.
Wouldn't this have been a bug? If not logged in, you try to add a ticket, and you correctly input the captcha, and miss a required field, the captcha disappears, that doesn't seem to be proper function.
I'm trying to go back to the original installation files to start again, but I just have to remember how I opened the tar file.
** Every time I open the tar file, it extracts another tar file.
** Got it extracted properly.
Great thanks! Just what I needed.
3 months later
try change script follow
see link: (http://osticket.com/forums/showthread.php?t=6059)
I just found some possible captcha bug.
Thank you,
bellacrazy74
2 years later
thanks. this worked for me..
if(!$_POST)
if(!$_POST)
thanks! I found this bug tonight and implementing your fix #1 worked.
it may be worth noting that I also have a MOD to use RECAPTCHA, instead of the one with osticket and this fix worked for me.
I commented out the original line of code and replaced it with your line of code and it worked like a charm.
NO CAPTCHA is needed for a user that is already logged in.
thanks and best regards,
nico
now i just have one more little bug to figure out and I'm good to go to production! :)
