Hi. I started using OSTicket a while back.
I have begun work on a mod that will allow Admins to create custom fields VIA the control Panel.
I will be straight foreward .
I am cloning the help_topic for the most part. I figure what is the point in writing all new scripting for a mod when the help_topic piece will suit the needs with some spiffy modifications.
The initial release of this mod will consist of the Admins will only be able to edit a predefined field. This is only for initial beta purposes. When I have the admin side to the point where all edits are flawless I will then add the functionablilty to add and edit new fields.
Admins do at this time have the ability to add as many different options to the single custom field as they wish.
For demo please visit http://PulseWebSolutions.com/octest(http://PulseWebSolutions.com/octest)
if the site is not up it will not be down long so please keep trying.
I do however need one thing from the developers if possible.
Can I please have a listing of the Files that have any pertinance to the
help_topics module.
Preferrably a directoy structure and file name
For example.
root/includes/client/open.inc.php
Becasue it has direct relevance to the Help Topics mod that comes stock with OSTicket.
Obviously since I am using the Help Topics Mod for a template I need to know every file used for its structure.
Most I have found but some help would be much appreciated.
Once project is finished I wll submit to OSTicket Developers for Deployment should they choose to utalize.
Please any and all feedback is welcomed and needed. I cannot stress how important it really is to get solid feedback and suggestions to make this a succesfull mod.
Thanks in advance..
Pfranco
I/T Manager , Systems Admin, Network Admin
