fpasinetti
What about this part?
Also, post a screenshot of Admin Panel > Dashboard > Information.
fpasinetti
Whoa..you are using PHP 7.4?! That’s not good. If you read the requirements for v1.17.5 it shows PHP 8.0-8.2. Upgrade PHP, reinstall all enabled extensions for PHP, restart the web server, and retest.
5 months later
I'm sorry ...
if I search for a ticket (specifically 263779 which has as its subject the serial of the failed component) and type that code (PS-RD-028UPS-0037) in the search box I am presented with as many as 60 results divided among 4 users (see screenshot) ... if I finally press ENTER the final result is: I am presented with 6 tickets (page 1 of xxxxxx). The ticket I therefore wanted was not displayed.
Thank you
    fpasinetti
    I believe - is a stop word in MySQL. It will break the text at the dashes and look for results that contain each part. So it will search for PS-RD-028UPS-0037 then PS then RD then 028UPS then 0037.
    Okay, I got it. I search with “x” and click on the icon.
    But it's not very functional ... I hope in a next release ...
    Thanks for the support
      fpasinetti
      What do you mean..? Nothing is changing in next release in this regard. Simply a MySQL limitation.
