Helllo
Normally it opens "OSTICKET-URL/open.php". There is the standard with no form selected.
Can i pre-choose the form somehow that if the user opens as example "OSTICKET-URL/open.php?topic=useraccount / create user account"
I have some specific case where in our intranet has some url to the support system where i'd like to pre choose the correct form.
Greetings,
calgia
    3 months later
    Thanks!
    Whree can i find the topic id?
    Need i to search trough database?
    Greetings,
    calgia
      16 days later
      KevinTheJedi found a long and a easy solution. topic id in database i can find.
      how abot the other fields like email?
      can i there add some tags that as example mail address is automatically filled with xy@domain.com without login?
      greetings,
      calgia
        calgia
        Form fields are randomly hashed so most likely not possible; unless you can guess hashes. 😉
