Even though it’s enabled at the webs server level does your Apache config file for the site have AllowOverride All enabled?
Hi, thanks for your answer.
I dont made any changes there and i'm not shure but it has worked somedays after i installed it the first time.
Then maybe the webserver just needed to be restarted or something? Either way glad it’s resolved now.
