Hi, on client-side, I want to change the '/' into ':' for the Parent : Child topics. For example, instead of Network / Internet Connection, I want it to be Network : Connection. How can I achieve this purpose?
Change slash in sub-topics
You will need to customize the code to accomplish this. You are on your own when customizing the code. Good luck!
KevinTheJedi I just need to know on which page is this controlled
9 days later
As Kevin said you are on your own when it comes to modifying the product.
That being said I would look in /include/client/
